Zetec sumps and flywheel question
Morning guys
Just need to know a few things Im going 2.0 blacktop zetec turbo with a mondeo engine in my s2 Firstly flywheels. I understand I need a 1.8 zetec one. Can I use a cvh efi flywheel and open up the bolt holes ? If so can I do it myself or does it have to be done by an engineering company ? Also sumps I need a 1.8 zetec sump and pick up. But Is a 1.6 zetec sump And pick up the same ? And thirdly cams My head is missing the u brackets that run between the cam lobes to bolt the cam shaft down ( the bearing cap things) lol. Can I take these from any zetec head ? I've been offered a free 1.6 zetec lump you see so I'm seeing if it's worth getting to use any bits Cheers guys |
afaik the cam caps are individual to the head so unless you have it linebored (sp) I suggest finding another complete head.
What management are you gonna use, mfi rs turbo flywheel has no pick up/trigger setup |
What is line bored ?
And I'm running omex Cheers mate |
google it, I understand what it would entail but describing it is another thing
1.6 sump, pick up pump, water pump and flywheel all fit.
silvertop that is......
I got a blacktop ,and if it's true I have to junk the head cos the cam caps are missing I'm gonna be seriously fucked off.
I will have a 2.0l silvertop for sale next month with a 1.8 sump with oil returns fitted. £150
Originally Posted by stevealien
(Post 5675629)
Originally Posted by studabear
(Post 5675696)
as a rule afaik the caps are individual to the engine/head, but you could speak tomachine shop etc
http://www.kelsey-forums.co.uk/cgi-b...num=1319576627 Geezer that replys is a ford main dealer tech |
Thanks for info so far guys
Stu, cheers for asking the question on the other site , appreciate that mate. Hopefully I'll get away with it , I'll speak to my machine shop |
Spoke to the machine shop and they reckon the head is scrap without the original cam caps.
The line boring is done at factory from new , and to be done would cOst hundreds. And apparently if I was to buy new cams I would use the old caps so that doesn't help me either. Just gotta hope the guy I got the engine off of can find the caps as they are numbered |
Ah shit news man, hope he has got them somewhere. Suppose another head will be easy to get hold of but its more costs.
So what's my sump options guys ? Only a 1.8 zetec or is 1.6 the same ?
Caps can not be swaped from head to head and must also be fitted in the place they are removed hence they are numbered.
You can use a 1.8 or 1.6 sump if you are using a silvertop engine yes. You can also use a cvh efi flywheel yes but you will still need the 1.8 cps and bracket |
iv got a 1.8 sump with a breather on oil return welded on the front and a breather on the back if anyone wants to make an offer
Originally Posted by clarke5700
(Post 5679629)
You can use a 1.8 or 1.6 sump if you are using a silvertop engine yes. You can also use a cvh efi flywheel yes but you will still need the 1.8 cps and bracket so i need a sump from a 1.6 or 1.8 blacktop or silvertop? and i need the cps from a 1.8 blacktop? cheers for your help |
just use the blacktop sump, i've used a 1.8 and 2.0 one look the same.
are you using a ib5/bc gearbox? the 1.6/1.8 focus flywheel is 220mm. |
I have a blacktop head here mate, came with my zetec engine but its 1.8,no good to me as im only going zvh.
If its any good whatsoever your welcome to it for free mate. :grin: |
Originally Posted by Statey
(Post 5679700)
If its any good whatsoever your welcome to it for free mate. :grin: thanks anyway,much appreciated :top::god::respekt: |
Originally Posted by luke19790_3
(Post 5679695)
are you using a ib5/bc gearbox? the 1.6/1.8 focus flywheel is 220mm. i thought the rst exhaust wouldnt pass under the 2.0 sump? doesnt the 1.8 sump have a step in it? |
With 1,8 sump you must also make a elbow for downpipe.
1,8 and 2,0 heads should be the same, only camshafts are different. |
© 2024 MH Sub I, LLC dba Internet Brands
