What Gearboxes Fit The RS Turbo
Hey guys wanting a stronger and higher top end box, do any diesel ones fit rs turbo with rs driveshafts. Not fussed about the LSD was just thinking about the benefits and non benefits of diesel one or similar? Is it worth changing or just leave as is? Thanks for any info.
Stronger box's that will fit are any IB5 (mk5 escort, Ka, Puma, etc..) with the starter in the right place (some have them at the rear) and that run a cable clutch (some are hydraulic).
If you want longer gears then yes a diesel box will of course work. The BC gearbox's (mk3, mk4 escorts and fiestas, orions of the same year) are all as weak as each other, including the magical diesel box that everyone seems to thing is stronger! :cry: lol |
later spec bc box with the bigger bearing as standard plus fully rebuilt with a 3.5 final drive will get you exactly what you want.
speak to jamsport they run them and tested on stuart collins car. |
Originally Posted by morph
(Post 5249818)
thanks karlos, I wasnt sure if they were any better, so ib5 is that of newer cvhs or any mk5 escort for example zetec etc? They the same or is 1.6, 1.8 etc diff ratios?
Will phone jamsport up thanks for info Sorry about all questions as I dont have a clue when it comes to gearboxes of which are which etc |
(Post 5249818)
Originally Posted by bigryrs
(Post 5249868)
Ive just sold stuart collins an mtx75 conversion with atb diff, so no more changing chocolate boxes lol
Originally Posted by JamesyRS
(Post 5249880)
Will phone jamsport up thanks for info Sorry about all questions as I dont have a clue when it comes to gearboxes of which are which etc Lots of the newer Fords have IB5 box's, Focus and Ka for example, but as I said you'll need to find one with the starter in the right place and a cable clutch, lots of variants. |
so what would I look for if was searching for one? Any specific codes etc? is IB5 on gearbox?
Fiestas mk4 and 5 have an IB5 with starter on the front
(Post 5249966)
google the company they supply alot of rs turbo owners club members up north like scotland so they do work well. |
(Post 5249880)
thanks for that dont mind that price :top: just seen alot of uprated boxes etc for 800 and dont want to go that far at moment as it aint a mega power car, I will give them a ring after xmas see what they can do for me cheers
© 2024 MH Sub I, LLC dba Internet Brands
