cvh trigger kit
Old Sep 3, 2009 | 03:36 PM
Mr.T's Avatar
Mr.T
Default cvh trigger kit
Where can i buy a trigger kit for my cvh? Ás i didnt drill the hole for the cps. So a trigger kit seems to be the next thing.
Old Sep 3, 2009 | 04:28 PM
Gadget's Avatar
Gadget
Spanner monkey
You have PM!!
Old Sep 3, 2009 | 05:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
www.triggerwheels.com for the wheel, and then your local motorfactors for a VR Sensor.
Old Sep 3, 2009 | 06:39 PM
XR2's Avatar
XR2
Burton sells a whole kit. Is working very well...
Old Sep 3, 2009 | 07:26 PM
Mr.T's Avatar
Mr.T
Seen that before. But never thought it would go together with the MS. Like to see how this one is mounted on the engine. any pics?
Old Sep 3, 2009 | 07:36 PM
XR2's Avatar
XR2
Works fine with the mappable trijekt injection, megasquirt should be able to use this, too...?
Old Sep 3, 2009 | 07:47 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
MS and most management systems will be fine with a 36-1 trigger wheel.
Old Sep 3, 2009 | 08:02 PM
Mr.T's Avatar
Mr.T
ok. thanks
Old Sep 4, 2009 | 08:02 AM
Rodreguez's Avatar
Rodreguez
so if u use the kit from burton u dont av change the bottom pulley, belt, bracket and alternator? this kit jus bolts on right?
Old Sep 4, 2009 | 09:05 AM
Gadget's Avatar
Gadget
Spanner monkey
Looks very similar to the kit i have made up when converting people's cars to efi, obviously this is a weber disc but the 36 -1 is no different dimensions and only cost about a fiver more!!
How much is the burton's kit out of interest??
Old Sep 4, 2009 | 09:08 AM
Mr.T's Avatar
Mr.T
Somewhere in the 100. You are cheaper so ill let you know
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
