Engine problems...
Old May 12, 2009 | 03:26 PM
stevedb's Avatar
stevedb
Default Engine problems...
Hi i have had 2 rs turbo engine blocks crack on me and was wondering what would cause this? Has anyone else had problems with blocks cracking? I have got another used block but am worried that it will happen again. Its getting expensive to keep replacing. The cracks are only hairline but enougth to keep blowing head gaskets.
Old May 12, 2009 | 09:30 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Woah! I've not had this happen but the only cause I can think of is heat! But I would of thought the head would crack first?!
Old May 13, 2009 | 08:21 AM
Chris69's Avatar
Chris69
I have but to be fair the previous owner had bored the block out to 86mm so it didn't take much of a gasket failure to do that beteween the cylinders i'm suprised it has happened on a standard block
Old May 13, 2009 | 09:54 AM
bezo's Avatar
bezo
powered by K26
where abouts on the block is it cracking?
Old May 13, 2009 | 03:47 PM
stevedb's Avatar
stevedb
I think its cracking between the water ways if that means anything to you? A friend of mine does all the work on the car im not very mechanical. I will find out exactly where its cracking. One time is bad but twice is taking the p*ss.
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
