Front panel
Old Apr 24, 2009 | 11:23 PM
white2lsr's Avatar
white2lsr
Default Front panel
Im after some info on fitting a front panel.
Firstly, does the panel come complete or in sections?
How much have people paid to have them fitted?
Does anyone have any pics of the job being done?
Cheers for any help.
Old Apr 24, 2009 | 11:26 PM
panelbeater's Avatar
panelbeater
front panel for what??
Old Apr 24, 2009 | 11:29 PM
white2lsr's Avatar
white2lsr
For a Series 2 RS Turbo
Old Apr 24, 2009 | 11:33 PM
panelbeater
the front panel comes as a slam panel with the two headlamp panels attached, the crossmember is seperate
Old Apr 24, 2009 | 11:36 PM
white2lsr's Avatar
white2lsr
Any idea on prices for them? looked on Beavers but cant tell what parts are the ones i need????
Old Apr 24, 2009 | 11:39 PM
panelbeater
i think the last one i fitted was about 6 years ago somewhere in the region about 70 quid ish from ford, not too bad to fit. have you got the wings off?
Old Apr 24, 2009 | 11:41 PM
white2lsr's Avatar
white2lsr
No, do they need to come off? Havnt really looked at it yet?
Old Apr 24, 2009 | 11:46 PM
panelbeater
the front panel sits between the inner wing lips and the outer wings, you can cheat somewhat as alot of people will tell you if your working to bonus. by cutting through the front panel along where it joins the wing really neatly i might add. then cleaning the underside then sliding the front panel under all 3 layers. it does look perfectly fine when done neat! as i've done my fair share when the mk4 esc was fairly new. there is a bead of sealer that runs along that joint anyway that hids the extra layer of metal. doing it this way you don't have to remove the wings and therefor looks original if spot welded back on
Old Apr 25, 2009 | 05:18 PM
xrmalin's Avatar
xrmalin
I got one a couple of months ago
front panel and cross member
i got the front panel just for the bumper mounts so i cut and shut it
can you tell ?
mark.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
gavt123
Sep 5, 2015 10:03 AM
cossirob
Sep 3, 2015 09:17 PM
