Hesitant Acceleration
Old Sep 20, 2008 | 02:48 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Default Hesitant Acceleration
Now ive sorted the turbo boost (well i think i have - boosting 8-10psi now) ive still got hesitance. If i feather the throttle it drives fine, and if i floor it it now flies. However if i drive with the throttle mid way it like hesitates.
Now the car used to be owned from new by my nan and i dont think she ever floored it so im wondering if its something to do with the throttle sensor or something?
How can i check this?
Old Sep 20, 2008 | 05:05 PM
Dragsteer's Avatar
Dragsteer
you are second owner? niice...
so car hesitates when it is off boost? under boost drives normally?
Old Sep 20, 2008 | 06:12 PM
notroubleclubber
yeah , its like when the throttle is at a certain position it hesitates which leads me to throttle position sensor and the way it was driven b4 (ie, no welly from my nan) makes me think its that. How do i check if it is?
Old Sep 21, 2008 | 02:04 AM
ROB7656's Avatar
ROB7656
sounds like timing to me
Old Sep 21, 2008 | 02:06 AM
ROB7656's Avatar
ROB7656
timeing....its late
Old Sep 21, 2008 | 08:56 AM
notroubleclubber
Is that easy to do? Never done timing b4.
Old Sep 21, 2008 | 01:47 PM
Dragsteer's Avatar
Dragsteer
you need strobe. go to some mechanics, it is very simple to do. But dont forget to remove map hose (hose which goes from ecu to inlet mainfold) . tell him to put ignition on 12 degree.
Old Sep 22, 2008 | 06:00 AM
notroubleclubber
getting the clutch sorted after welding done so will get it all done then. Cheers.
Old Sep 22, 2008 | 03:40 PM
notroubleclubber
Checked plug gaps were 0.7 and adjusted but still same prob (if worse). So getting timing looked at this week.
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
landaqmabba
Sep 15, 2015 07:16 PM
Marino
Sep 12, 2015 11:10 AM
