problem with abs system
Old Nov 30, 2007 | 04:01 PM
ricky_2006's Avatar
ricky_2006
Default problem with abs system
i got a escort s2 rs. its was factory standard with abs. and ive now found out after having it for few months tht my mot failer due to the previous owner taking half the system off. why would someone do that. coz u got to hav abs illuminating when you turn key, but mine aint doin that, half the wires have been fukin cut so my car wont pass
Old Nov 30, 2007 | 04:24 PM
Red_bull's Avatar
Red_bull
take it all off!
The abs system is crap!
Old Nov 30, 2007 | 04:41 PM
ricky_2006's Avatar
ricky_2006
mate, it wont pass because it has to illuminate on the dash when the key is turned
Old Nov 30, 2007 | 04:59 PM
adduk's Avatar
adduk
if it isnt there it cant fail on it,take it all out and take the bulb out from behind the clocks.job done.im taking mine out coz its crap.
Old Nov 30, 2007 | 05:23 PM
ricky_2006's Avatar
ricky_2006
course it can fail. if its factory fitted from standard then it has to be there. it has to illuminate to tell you wether its working or not. it cant pass without it because its factory fitted mate
Old Nov 30, 2007 | 05:57 PM
antony215's Avatar
antony215
Escort Rs Turbo
If it's all been changed to "non" abs PROPERLY then it will pass regardless if it came out the factory with abs theres plenty of people on here that have removed there ABS and have had no problems passing an MOT.
Old Nov 30, 2007 | 06:43 PM
addiction's Avatar
addiction
technically the warning light should work as when they enter the car's details into the computer it comes up on the printed sheet telling the tester how to check the abs warning system!
Old Nov 30, 2007 | 06:55 PM
turbodan's Avatar
turbodan
if its not fitted i doesnt have to be tested factory fit or not. take it all out
Old Nov 30, 2007 | 07:57 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Mines been taken out
Old Nov 30, 2007 | 08:10 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Mines been out for around 6-7 years and has passed a legitimate MOT every year.
The only trace I have of ever having had it is the teeth on the driveshafts.
Old Nov 30, 2007 | 09:54 PM
adduk's Avatar
adduk
it doesnt have to be there to pass.if it is all taken out properly as said above there is nothing there to fail it on.like having fog lights on the front if they arent there doesnt fail if they are and bulb out it will,same idea.know loads who have had it removed and passes mot.may be wrong.if it bothering you that much repair it and you will be happy then.good look either way.
Old Dec 1, 2007 | 05:36 PM
addiction's Avatar
addiction
Front fog lights dont come under the MOT only rear one's!
Old Dec 1, 2007 | 08:16 PM
djmillsy's Avatar
djmillsy
Fife Radge
what servo did you use or did you blank the rs one off
Old Dec 1, 2007 | 08:31 PM
adduk's Avatar
adduk
use the rs turbo one just change the bottle for an xr3i one with no abs outlets on it,bottles just pull off i think n push other onr on
Old Dec 1, 2007 | 10:58 PM
Chris69's Avatar
Chris69
the rst is an old beast now, just remove it, and as long as the brakes and the hendbrake warnng lights works the car will pass.
my current car has no abs, it passed as the MOT tester said to me the test is so basic(light coming on at static etc) it would be hard to fail the car. if somone fails it mate there not following the guidelines for the year of your car but just following modern test standards that do not apply to a 17+ year old car
i may be talking sh!t its just wot i've been told
Old Dec 2, 2007 | 12:52 AM
Billy_RS's Avatar
Billy_RS
Rip that off asap.
Cause more problems then it solves
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
coscor86
Sep 20, 2015 01:21 PM
dms04
Sep 11, 2015 01:57 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
ST-170
Sep 4, 2015 11:02 AM
