what causing this...
Old Sep 21, 2007 | 08:56 PM
Dragsteer's Avatar
Dragsteer
Default what causing this...
Since I have this car one problem is never solved. So all advices is welcome, because this is my only problem but it is very annoying.
When I flor it, boost start rising, car accelerate, but then suddenly car start to breaking, I mean engine doesnt accelerate good anymore, and I hear that engine change noise a little, just like you go uphill and flor it but revs are too low.
This problem I noticed in second and 3th gear.
I set ignition timing , fueling (about 12.3 : 1), new sparks, new spark cables.
what you advice me to see? maybe cam? what are simptoms of worn cam?
Old Sep 22, 2007 | 09:22 AM
Fiecos Dan's Avatar
Fiecos Dan
Sounds like cam's your issue.
remove it and measure the lobe's with a ditital vernier.
Old Sep 22, 2007 | 09:27 AM
haz87's Avatar
haz87
What ignition timing have you set?
Old Sep 22, 2007 | 10:58 AM
Dragsteer's Avatar
Dragsteer
12 degrees. But I try retard it and advance it and same problem.
fiecoss dan: thanks, I hope so that cam is problem because everything else is checked.
Old Sep 22, 2007 | 11:26 AM
Rick's Avatar
Rick
collapsing boost hose.
Old Sep 22, 2007 | 04:13 PM
Drag_steer's Avatar
Drag_steer
how u mean collapsing? hose which goes from IC to inlet plenum ( to aluminium pipe)? But boost dont fall when I drive, only car start go slower and I hear different engine sound.
Old Sep 22, 2007 | 05:50 PM
MarkXr's Avatar
MarkXr
No he means the hose from metering unit to turbo...... The one that's being sucked at by it's girlfriend Miss Garrett..
Old Sep 22, 2007 | 07:37 PM
Dragsteer's Avatar
Dragsteer
ok but there are hard hose with steel inside if u know what I mean. So I think turbo cannot suck this hose at o.5 bar. If u mean that. So maybe is cam worn? Can simptoms which i wrote in first post be simptoms of worn cam? Fiecos dan said yes
Old Sep 23, 2007 | 12:43 AM
Fiecos Dan's Avatar
Fiecos Dan
Could be a few things.
but it takes 1-2 hours to remove, check and re time a cam.
Old Sep 23, 2007 | 09:25 AM
Drag_steer's Avatar
Drag_steer
yes. I will go see cam
Old Sep 24, 2007 | 04:22 PM
Drag_steer's Avatar
Drag_steer
I think I solve problem...
before, I have boost 0.6 bar in second gear, which mean in 3th and 4th gear I will have more boost. I didnt feel cut off, because when I saw 0.7 bar in higher gears I change gear
so I turn down boost and now car driving fine, no strange sounds, no "handbrake up" feel.
Old Oct 3, 2007 | 05:08 PM
Dragsteer's Avatar
Dragsteer
I again have same problem, but I noticed that problem which I describe in first post, is very common when car is hot. I really dont have idea anymore...
Old Oct 3, 2007 | 05:50 PM
Fiecos Dan's Avatar
Fiecos Dan
so what have you checked/changed since trying to sort?
Old Oct 3, 2007 | 06:32 PM
Dragsteer's Avatar
Dragsteer
I have this problem since I bought car. I set fueling at full throttle at about 12:1 , idle mixure is ok, I check belt, timing is ok, ignition timing is set to about 12 degrees, changed sparks, cables, boost hoses. And again, when I suddenly push throttle, for example driving at 2000 rpm in 2nd gear,and flor it, engine wont pulling so good, expecially when engine is hot. Goes good, and at about 3000 rpm starts do like I pull handbrake.like I give it to much gas, and engine start to choking.but sparks are coloured like rust or chocholate. I dont know what to see.next on my list is see cam. I dont have other ideas.
Old Oct 3, 2007 | 06:50 PM
Fiecos Dan's Avatar
Fiecos Dan
No point keep asking the question if you dont do anything since the last time you asked.
CHECK CAM............
How are you measuring the AFR?
Old Oct 3, 2007 | 07:33 PM
Dragsteer's Avatar
Dragsteer
With wide band lambda while driving. Will check cam and tell here results
Old Oct 3, 2007 | 08:07 PM
Fiecos Dan's Avatar
Fiecos Dan
so whats the afr when its bog's?
Old Oct 3, 2007 | 08:28 PM
Dragsteer's Avatar
Dragsteer
AFR on full throttle, at about 4500 - 5000 rpm on 0.5 bar , is about 12.3
Old Oct 3, 2007 | 10:37 PM
Fiecos Dan's Avatar
Fiecos Dan
So whats the AFR when the problem is happening?
Old Oct 4, 2007 | 08:19 AM
Dragsteer's Avatar
Dragsteer
It is the same. I didnt see difference in afr. This problem I dont noticed every time. I will go check cam soon
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
rsturbo27
Sep 5, 2015 05:08 PM
