efi flywheel question
Old Jul 2, 2007 | 08:18 PM
jonesymk2's Avatar
jonesymk2
Default efi flywheel question
when the bottom pulley timing mark is lined up with the timing mark on the cam belt cover so its showing tdc,where should the missing tooth on the flywheel be,should it be lined up with the cps or should it be before or after the cps
Old Jul 2, 2007 | 08:31 PM
Chris69's Avatar
Chris69
just wondering why ur asking as the flywheel will only go on one way due to its staggered hole positions.
and as far as i remember the double hole is before the cps
Old Jul 2, 2007 | 10:44 PM
mark-rst's Avatar
mark-rst
90 BTDC the missing tooth is
Old Jul 2, 2007 | 10:53 PM
jonesymk2's Avatar
jonesymk2
so if i line the bottom pulley up with tdc the missing tooth on the flywheel wil be at the bottom of the flywheel yeh,the reason im asking is because ive had a timing light on my car and its showing 60degrees of advance so just trying to make sure everything is ok before i take it to be setup
Old Jul 2, 2007 | 11:10 PM
mark-rst's Avatar
mark-rst
You cannot get the flywheel wrong due to the offset of the bolts as chunt69 mentioned
Yeah that sounds right...
What ECU you got?
Old Jul 3, 2007 | 11:57 AM
JesseT's Avatar
JesseT
Some older timing light simply show wrong witha wasted spark ignition. It wouldn't run with 60deg advance anyway. If the timing light has an adjustabel advance trim, then set it to zero and read the advance from the pulley marks.
Old Jul 12, 2007 | 08:50 PM
jonesymk2's Avatar
jonesymk2
if i set the timing light at zero i cant get a reading from the bottom pulley as the timing mark is to far round before the timing marks on the lower cam belt cover
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
