setting timing
Old Apr 29, 2007 | 08:22 PM
RodgeRS_Turbo's Avatar
RodgeRS_Turbo
Default setting timing
can anyone explain how to do this?
ive lost my hanyes manual
I thought I had done it, but giving it a turn with the spanner for a safety check i think the valve and piston could be touching
cheers
Old Apr 29, 2007 | 08:30 PM
sm's Avatar
sm
iirc... the mark on the bottom pulley should be on the 0 mark on the bottom cover, the cam belt pulley should have the arrow on it inline with the mark on the head and the rotor arm should be pointing to the number 1 on the dizzy if the rotor arm is pointin to number 4 remove the cambelt and rotate the crank 360 degrees refit cambelt and the rotor arm should be pointing towards number one lead on the dizzy
Old Apr 29, 2007 | 08:31 PM
sm's Avatar
sm
iirc... the mark on the bottom pulley should be on the 0 mark on the bottom cover, the cam belt pulley should have the arrow on it inline with the mark on the head and the rotor arm should be pointing to the number 1 on the dizzy if the rotor arm is pointin to number 4 remove the cambelt and rotate the crank 360 degrees refit cambelt and the rotor arm should be pointing towards number one on the dizzy
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
Zoggon
Aug 10, 2015 10:39 AM
kyle_st200
Ford Focus (All Models)
Aug 7, 2015 06:06 PM
slammedorion
21
Aug 6, 2015 11:38 AM
