Spark plug condition.
Old Apr 18, 2007 | 01:03 PM
danskfocus's Avatar
danskfocus
Default Spark plug condition.
Hi !
I am preparing my RST S2 for the new season, and today i changed the plugs.
Would any of you comment on the condition (colour) of the old ones, as i am a little unsertain about it needing setting up.
The enginespec. is standart.
Thanks
Old Apr 18, 2007 | 01:11 PM
Alex_86's Avatar
Alex_86
hm, pics did not come up...
but you could look in a haynes manual.
den svenske (står bakerst), da jeg er usikker på om den engelske har det samme
edit: now they did came up, looks normally
Old Apr 18, 2007 | 03:20 PM
Arjan's Avatar
Arjan
running a bit hot, could be running lean or too much ignition advance
the right colour should be beige light brown.
run standard escort rs turbo plugs,theyre very good
Old Apr 18, 2007 | 03:58 PM
danskfocus's Avatar
danskfocus
Ok, i think i will check ignition advance first.
The new ones i put in are Motorcraft AGP 901C.
Old Apr 19, 2007 | 07:29 PM
Series1Dry's Avatar
Series1Dry
The picture in the Haynes which closely resembles your plugs says plug overheating, check ignition timing, fuel octane rating too low or fuel mixture too weak. The Motorcraft 901 should be perfect for the S2
Old Apr 19, 2007 | 08:42 PM
Rick's Avatar
Rick
It all depends as to how u were driving before you took them out. However, if the car is on std management, i would sugget that it is running a little lean, as they appear quite hot. What plug are they? Maybe a grade to hot. Is the car on std boost?
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
