Throttle Position Sensor
Do you know the best position to have this in as you can adjust it?
Mine is set at half way at the minute but I don't know if that is standard.
Dave
Dave
It's not a potentiometer, it's just two microswitches in a potentiometer like enclosure. You should adjust it so, that it clicks when the throttle goes to idle or full. If you're somewhere in the middle, the ecu doesn't know where. S1/S2 does have a after-run fuel cut-off. You can clearly see it working if you rev to 4000rpm and suddenly let go of the accelerator. The revs drop really fast to about ~1800rpm where you can hear/feel the motor kicking back into action again. The fuel-cut is operated via the EMFCPA (Electro Magnetic Fuel Control Pressure Actuator).
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
