D locking
Old Aug 31, 2007 | 01:51 PM
psygnosis's Avatar
psygnosis
Default D locking
What are peoples opions on d locking a escos im thinking on the secruity side of things or shall i just leave it
opions please
Old Aug 31, 2007 | 01:53 PM
ECOS95's Avatar
ECOS95
If you d lock you can't enable the Dead locking. I always use the key to dead lock then arm the alarm. If you just use the alarm it only locks not Dead lock. Def the case on the ST not sure about the BT.
Old Aug 31, 2007 | 08:45 PM
SortedCossie's Avatar
SortedCossie
as above the deadlocks don't work when de-locked.
plus, if no door locks then they'll just go for the boot lock or bust a window.
if they want it that bad then nowt you do will stop em.
Old Aug 31, 2007 | 09:38 PM
L3 COS's Avatar
L3 COS
personally im not a fan of d locking but everyone to there own,as said above if they want to break in they will one way or another..
so wots the point..
Old Aug 31, 2007 | 10:13 PM
dave cos4x4's Avatar
dave cos4x4
i've never used the dead locking.
does it enable everytime you lock it with the key or have you got to lock it a certain way.
Old Aug 31, 2007 | 10:39 PM
Escos Jam's Avatar
Escos Jam
I delocked my tailgate but thats all. Keeping the door locks.
Old Sep 1, 2007 | 03:50 PM
ECOS95's Avatar
ECOS95
Turn the key left then right, not sure if its the case on the BT. You'll hear the dead locking working.
Old Sep 1, 2007 | 07:35 PM
THE RADMAN's Avatar
THE RADMAN
on my last one i had the dead locking on remote, pressed one button to lock then another to deadlock
Old Sep 1, 2007 | 07:57 PM
SortedCossie
really, i wasn't aware that could be done. on a small escort you have to turn the key to left then hold over to right for 2 seconds to push the deadlocks over.
Old Sep 1, 2007 | 08:00 PM
THE RADMAN's Avatar
THE RADMAN
it was a small t one on a clifford,any decent auto electric place should be able to do it that way
Old Sep 1, 2007 | 08:02 PM
steviecossie's Avatar
steviecossie
i would never d/lock mine
but everyone has diffrent tastes
Old Sep 1, 2007 | 08:17 PM
MarkN's Avatar
MarkN
You can enable the deadlocking via a remote but many alarm companies are reluctant to tamper with it as if the alarm becomes active it can lock you in the car. You could probably get it to work with another pair of relays that switch the deadlocking from the alarm lock/unlock signal.
If you get it wrong you can deadlock the car by locking the door from the inside and then you can't get out if you haven't got the key to wind a window down or open the sunroof. I think the boot release is disabled when the car is deadlocked.
Old Sep 2, 2007 | 04:52 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
mine is delocked and tbh i dont care what people say i like it and its safer... and as said deadlocked, delocked whatever if they want it they will do anything!!! So just do what you want
Old Sep 2, 2007 | 05:18 PM
ECOS95's Avatar
ECOS95
I d locked my RST, would I do it again NO. It was great until you have issues with your alarm, central locking or car battery and you look a complete idiot climbing through the boot, providing you haven't d locked that either. Also what do you do if your car battery runs flat, not like you can unlock the car with the key.
As said above the choice is yours.
I'd rather theives put a screw driver in the door lock than try to bend the door or smash windows.
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
