Fuel pump and swirl pot set ups
Anyone got any pics of these installed :top: :top:
Thanks Paul |
I think you'll find he means EscCos fish batterer! :cry: :blabla:
Why do you want photos, you can never see them, as everything hides under the car :cry: :p?
dangerous - reyland Blimey thats a bit mental :eek: :top: :top:
Adamskid shhhhhhhh Mike I wanted to see how it mounts up :blabla: |
Its Pro Alloy tank & swirl pot Paul :top: :top:
The lift pump on the side is a Holley 110 GPH :eek: Martin ordered it in from the US for me No point in having a lift pump that cant keep up with the 044 bosch main pump as the pot will run dry Routes :(dash10) tank - liftpump- top of swirlpot - bottom of swirl pot to 044 - (dash6) 044 out to filter - filter out to fuel rail - fuel rail out to pressure regulator - p/r out to top swirl pot - top of s/p back to tank standard saff cos filter in Pro Alloy bracket iwth 044 |
This is my one that had to be cut about to make way for the Magnex exhaust, hence why it is a bit rough and ready, but I don't care as only the cats eyes and road kill get to see it normally :cry:
https://img.photobucket.com/albums/0...R/a7b00e0e.jpg |
Think this'll be my next step for the winter.............If i ever get it sorted as it is now! :cry:
Paul, ill get some pics for you tomorrow.
but my intake pump lifts to a swirl pot in a boot enclosure which also houses my 044 fuel pump. all nicely consealed within a tank in the boot. but may just go for something mildly along the lines of what Dangerous has. Dangerous, looking very good :top: Bit of a ropey pic https://img.photobucket.com/albums/v...e12/1brace.jpg |
but my intake pump lifts to a swirl pot in a boot enclosure which also houses my 044 fuel pump. all nicely consealed within a tank in the boot. https://img.photobucket.com/albums/v...e12/1brace.jpg |
For a road car, you'd be mad to put it all in the boot - the noise is horrendous :cry:.
Mine has been like this set up for SEVEN years with no issues what-so-ever :p. |
turn the stereo up then :cry:
but not to worried, what with the rear beam being solid mounted aswell - the rear diff grinds away when decelerating :cry: |
Dunno if it a silly question but do you get the smell of petrol inside the car?
only ever got a slight smell of fuel if it was a very hot day, and it was only when i first started the car up... smell had disapeared within a few seconds. :?
© 2024 MH Sub I, LLC dba Internet Brands
