any capri owners in the house? post in here
#88
My Tickford, its done 46,000 miles and only 1,000 in the last 9 years ive owned it.
My 280 pride and joy, 45,000 miles. It took me ages to find a real clean and tidy one that i was happy with. Again ive owned this for nearly 10 years and its done just under the 10,000 miles in that time.
This is my other 280, it was a bargain as the owner needed a quick sale as he needed to raise funds to go on a tv poker show, which he won! It needed abit of work as it had done 80,000. Ive had this one now 5 years and ive just finished restoring it and it will be up forsale later this year. Its just done 7 miles in 5 years...... just a trip down to the mot station this month!!!..... not bad eh.....
#97
Yep got a Mk3 shell converted to mk2 xpack project 3.0 jps will be the finished look , Five linked and coilovers , discs all round ,quickrack and shift ....
http://www.kodakgallery.com/BrowsePh...id=0&ownerid=0
#99
Capri V8
My V8 Capri
Well im new here, but here is my baby:
The Car:
Well it is a 1986 Mk3 Ford Capri, which has been modified to take a Rover 3.9 efi V8 and Sherpa 5 speed gearbox,it has a sports twin exhaust system, special made 2 piece prop, with 2.8i Capri Lsd Axle with cosworth discs (non vented) with sierra calipers, bilstien front struts with cosworth discs (vented) and ap 4 pot calipers, powersteering rack from 2.8i Capri which is mated up to the Rover powersteering pump,
and to finish the chassis of is a set of 16" monza alloy wheels,
The Engine:
Its the latest rover stiff block design (not 4 bolt mains version), has a 285 piper high lift cam with Crane hi-rev lifters (hydrualic), Chrome molly adjustable push rods, and steel vernier timing gears,
ARP mains studs, ARP big end studs and ARP head studs,
factory efi system with JR race induction filter, 4.6 ported Tempest Thor heads, Factory oil pump with high pressure spring, a FSE high pressure fuel regulator, lightened flywheel with a AP-Racing clutch and a Highpower 200i Nitrous Oxide kit with progressive nitrous controller.(only 75bhp at the mo)
Mallory Unilite dizzy, Mallory Hyfire VI Digital Multi Strike Ignition Control and Mallory Promaster Coil, (the Mallory Componets kindly supplied/sponsored by Allan Ross)
The Inside:
Standard Capri except for rear seats removed a Saftey Devices 6 point roll cage fitted, Battery moved to the boot,
Recaro half leather front seats, momo steering wheel, Autometer 5" Sport Comp rev counter/shift light and line loc for front brakes,
Performance:
0-60mph ?
1/4 ET 13.729 @ 102.04mph
The Car:
The Engine:
The Inside:
Performance:
0-60mph ?
#101
Capri V8
If you can weld and have access to metal, not that expensive
the hardest part now is the manifolds as Caprisport no longer do the v8 conversion,
you can get away with using P5 rover manifolds, and caprisports drawings to make the other mounts etc needed,
#102
Thought i pop on and say hi, ive got a 2.8 injection y plate in black !
up in bonny scotland, also had mark1 in silver and around 10 others over the years... kinda like the a-z of capris.
anyway hi, and i hope i can pick ure brains from time to time.
cheers cazza.
cheers cazza.
#103
Hi guys!
I`m from Hungary, recently staying in London. I had originally a 2.3 V6 Capri from Germany later I had changed the engine for a 2.8 carb model from a granada. I put a K-jet on it and the same electrical ignition like the 2.8i has.
At the moment I`d like to tune it up more and need some advice.
The engine is almost rebuilt, ported heads,new bearings,rings,seals. Only the camshaft is not on top i think.
It has already 4 paddle racing clutch, 2" exhaust and lsd. Run 10.6sec on 1/8mi.
I`d like a wilder cam,lightened flywheel, 5speed gearbox, stronger clutch cover, nitrous and better ignition system if it`s necessary or anything else
could make this project better. I don`t want turbo.
What type of cam,gearbox, clutch cover and ignition upgrade do u suggest?
#104
i have a beige 16L i inhereted it when my grandad died its rotten as hell but one day i will do somthing with it i got it when i was about 15 im 21 now all ive done is take the engine out i will eventually put a v8 in it do the body work and paint it black but till then it just sits in a garage rotting im gonna do my fiesta first to get an idea of what its gonna take to restore a car
#107
capri lover
Hello,
I have a mk1 capri, and feel very much in the minority!! its a 1971 1600xl, that i have subtly modified, with a 16v rover engine. I have a photo or two, and when i work out how to post them i will!! It looks like s**t and goes like stink, however traction and braking are major problems!! I love mk1 capris, I bought a mk3 to reshell my engine and running gear into a while ago, but it just wasnt the same, despite being a much more solid and better car(was bought by Jon Betts who wrote for classic ford and street machine at the time). Still got thios prefacelift mk1 thats tax exempt and very solid from ebay, and we are rocking now!!
#108
Ok i got the idea of this photo thing, so here we go!! hope it works. Just for reference, best 1/4 mile 13.6@110mph, still spinning in 4th gear!! I love mk1 Capris, although i like all capris. Anyone fancy a race, im a regular at York raceway, and its a good leveller!! Only running 75BHP of gas, if you spotted the solenoids. The lads at Doncaster speak very highly of the red mk3 V8 above, sorry im a tad faster mate, with only 3.5 litres, i think it was a timing error!! mINE IS STRIPPED TO THE BARE B******S, i dont even have carpets!! Traction and stopping may always be a problem though, however with 110 terminal speeds I should with a little morte traction be running low twelves next year.
#109
Wow there are some beauties here.
Here's a few pictures of mine, I just bought it yesterday and will collect it in a few weeks.
Here's the spec sheet:
1979 FORD CAPRI 2.8i Special 3dr Fastback,
22,500 miles, FORD CAPRI V8 CUSTOM. Originally a 3.0S but has had an extensive amount of work done to bodywork and an engine conversion but interior is original. 3.5 rover v8 p6 engine and gearbox. 10.5 - 1 comp, k and ns with bbw needles, 4 pot calipers resealed, new 2.8 master cylinder and new rear wheel cylinders and all flexi hoses. new cam, followers, big ends and mains in 1996 and history shows 5000 miles since then. engine runs sweet and sounds meaty as it should. electric fuel pump in boot and twin electric fans for cooling. excellent interior. full custom bodykit de bumpered and mirrored. paintwork is believed to be nissan sunburnt orange and it is a pretty good paint j
#110
i own a 2ltr x-pack and richard grant kitted mk3. new engine being built for it using the cosworth 205 block and the injection setup from the sierras. thats the runaround. the new project is a mk1 that i recently picked up, shes a german import, lhd for the time being, with a 2600 v6 up front. shes scheduled for a stripdown and a 24v cossie transplant. ALOT of bodywork to be done first.
has anyone else on here running 24v's explored the custom inlet route as the standard issue is very restrictive. what sort of power are people getting from them?
cheers.
cheers.
#112
some pics of the 1.6S now it's finished for this year, next year i need to: get the RS 7.5's polished up for the shows they're gettin a little dull, need to find a turbo tail and brown 3.0 S interior.
#114
Hiya, thought id put a couple of better pics of me old mk1 on for your perusal!!
I love slotmags!!
Shot of obligatory nos bottle! Bootlid is fibreglass, thats why it isnt painted inside.
Shot of interior, doesnt do it any justice! probably never will finish painting the floor! Its all solid though. Ali door panels are a bit rough, and prob weigh more than the originals!!
She is gonna get a revamp this year, with some wider wheels and better tyres (remoulds really are crap!!) Pics will follow when i start, time and money permitting. Then i might get around to fitting the LSD, and hopefully my ETs should drop to low 12s high 11s, perhaps a sniff more gas, and hopefully a nitrous controller.
I love slotmags!!
#116
hey all, just thought id say hi to you lot, i live the next village along from nosman's v8 mk1.
Im 18 in a couple of weeks and i have a '84 1600 laser.
I bought it just to see if i liked capris as i only ever drove one when i was 10 before i got mine
Its had one main owner since new and then 2 short term ones, with 46K now on the clock which im sure is genuine.
Its for sale as of a week or two as im going to get a bigger engined one.
#118
Hello, new boy here, thought i ought to introduce my 2.0 Laser. It's a work in progress, needing a bit of restoring to get it looking nice again.
The bodywork round the front end is rough as a badger's backside - it needs new wings, some welding on the valance, and a new bumper - but the floorpan is solid and the mechanicals are decent too. Only mods so far are to the front brakes (drilled and grooved brake discs, Kevlar pads, braided hoses and reconned calipers) as they were pretty lethal as standard!
Eventually, once I've got rid of all the rusty bits, I'm planning on having it resprayed in Radiant Red, and doing a bit of mild tweaking to the Pinto motor.
#119
Looks good to me mate, tune the 2l they go great!! My mate put an fr32 cam n a 38dgas on his, had it tuned n it when really well.
More than a match for my old 325i BMW!!
Mr Britax cooper did you buy the mk1 or are you staying with the mk3?
#120
I should know in a week or so.
