my escort cossy
Most of the cars in this post looks fuckin wicked mate, both of your cossie's are amazing!!
There was a small pic in one of the mags of the Auralis Blue one wasnt there last month??
What's the spec on the one with 19's on it?
Oh and BTW do you own all them jags too!!??
Nice to see your cars after you've given me alot of advice lately, Thanks!
As chris hasn't replied and his got shitty 56kb dial up, i'll answer.
Yellow car is a Mk2 escort and its a road car.
Yeah his in this months PF @ the essex meet.
Yes the rumours are true he is shorter than Danny Devito
The pics of the Aurilis cossie dont make it look as good as it really is, the little pic of it in PF this month looks sooooooo much better, the wheels look the so tough but not over the top, you know it looks like it could have left the factory with them on, i love it!!!
spec of the blue one is massive- not in bhp, but in modifications.
1996 lux with everything inc. twin airbags leather, and aircon.
19'' OZ Superleggera silver
Magnex- no cats
T28 hy-brid with GTi-R comp. wheel etc360, cut blades
Chip with boost limiter removed
Blitz air filter cone & breathers
HKS Iridium plugs
B & m short shift kit
Clear lights front & sides
Red & clear rear lights
H&R/ Gaz coil overs- decked to f*ck
Vibratechnics engine mounts
Poly bushes all round inc gear box cradle bush
Modified front grill
2 alarms & tracker
Alpine head unit and Pheonix gold install inc. amp, sub etc
Every samco hose available + more in every different colour
Bailey power steering, header, swirl pot and mirror image oil seperator
Bailey dump valve
1/4 mile 13.5sec @ USC 2003 santa-pod
283bhp & 284ftlb torque @ 3350rpm
Magnex- no cats
HKS Iridium plugs
2 alarms & tracker
Bailey dump valve
HKS plugs!!!
Thanks for everone's comments on my car! It is difficult to modify an Escort Cossy without f8cking it up and ruining it. I don't have much else
planned for next year just bigger brakes.
cossymad, Could you email the pictures and i'll resize em for ya without losing the quality as there a little big. I'll edit ya post with the new pics.
adamjenkins@btopenworld.com
SPEC FOR THE ORANGE ONE, SO FAR AS THINGS KEEP CHANGING!!!
ARP 500,000 PSI CON ROD BOLTS
BD14 CAMS FROM PIPER
COLLINS REMAPPED CHIP
COMPLETE GASKET SET (FORD)
DIRECT PORT NITROUS +0-200BHP
DOUBLE VALVE SPRINGS
MOTORSPORT BLUE INJECTORS
INLETS AND EXHAUSTS PORT MATCHED
KEVLAR CAMBELT FROM PIPER
P8 ECU
OVER SIZED PISTONS
NEW HYDRAULIC FOLLOWERS from PIPER
NEW OIL STEM SEALS FROM FORDS
NEW VALVE GUIDES FROM WINSPEED
PACE RS500 INTERCOOLER IN BLACK
MODIFIED INLET CHAMBER
PORTED HEAD & SKIMMED
SAMCO COOLANTS
SAMCO COOLANTS ancillaries
SAMCO TURBO HOSES
STEEL LAYERED WRC HEAD GASKET
TOTAL SEAL PISTON RINGS
VERNIER PULLEYS FROM PIPER
GPA COIL
2WD EXHAUST MANIFOLD
AP CLUTCH?
QUAIFFE BOX
FERODO DRILLED DISCS ALL ROUND
FERODO DS 2000 PADS ALL ROUND
GAZ COIL OVERS ALL ROUND
TINTED REAR LIGHTS
TINTED FRONT FOGS
TINTED FRONT INDICATORS
FULL CAGE WITH DOOR BARS & REAR CROSS
FULLY PAINTED UNDER NEATH
2X COBRA EVOLUTION TECHNOLOGY (YES £1150 EACH!!)
SPARCO MONSTER 6 POINT 3'' HARNESSES
OIL TEMP GAUGE
OIL PRESSURE GAUGE
TRANSMISSION TEMP. GAUGE
WATER TEMP. GAUGE
FUEL PRESSURE GAUGE
NITROUS GAUGE
SPARCO GEAR KNOB
SPARCO STEERING WHEEL
3BAR BOOST GAUGE
LAMBOURGINI ORANGE PAINT
MODIFIED GRILL & BUMPER
SIDE EXIT EXHAUST & MONGOOSE STRAIGHT THROUGH!
PROGRESSIVE NOS CONTROLLER 0-200BHP
CARBON CENTRE DASH PANEL
FRONT STRUTT BRACE IN BLACK
HEADER TANK BLACK ALLY (BAILEY)
OIL SEPERATOR TANK BLACK ALLY (BAILEY)
POWER STEERING TANK BLACK ALLY (BAILEY)
SWIRL POT BLACK ALLY (BAILEY)
TWO BLACK DUMPVALVES
T34 STAGE 3 HYBRID NEW (SCOTT)
TURBO DAMPER BLACK (BAILEY)
P8 ECU
OVER SIZED PISTONS
SAMCO COOLANTS
SAMCO TURBO HOSES
GPA COIL
AP CLUTCH?
QUAIFFE BOX
TINTED REAR LIGHTS
TINTED FRONT FOGS
OIL TEMP GAUGE
OIL PRESSURE GAUGE
WATER TEMP. GAUGE
FUEL PRESSURE GAUGE
NITROUS GAUGE
SPARCO GEAR KNOB
3BAR BOOST GAUGE
Joke
