wiring diagram for diesel relay.ELECTRICTIONS ????????? Help
As title ,
Im wiring in a new Diesel heater plug relay into a friends car , i have robbed the relay out of a old sierra and have the following colours
Thick red ( presume permenent live from battery )
Thick red with yellow trace ( presume 12v out to plugs)
Brown obvoiusly earth
Black medium gauge where does this go ?
thin gauge brown with yellow trace, ??? Ignition switch or dash lite ?
Thin gauge black with green trace.?????Ignition switch or dash lite?
as you can see there are 6 wires , these i presume go to the following
12V perm live
12V to plugs
earth
Ignition switch
Dash board light
But whare does the 6th one go ???????
i think its the black one thats left as when its been cut off the donor car loom it has about 6 other black wires comming from it , as if its to supply a live to various other compunents ???
any help greatfully received
Muchos gracias amigos
12V perm live
12V to plugs
earth
Ignition switch
Dash board light
could it be the earth for the relay?
or possibly for the dash light?
if you can tell me what relay it was in the sierra then
i can possibly/probably tell you what the wires
originally did
originally did
Its not a earth , theirs a brown wire there already , brown being earth on all fords .
relay came off a J reg 1.8 diesel saph
part noon the relay is
90 BB 6M092
89 90 22
12V 70A
is that any help ???
90 BB 6M092
89 90 22
12V 70A
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
