shes a non runner
went to start my car after work today and it wouldnt start the only thing different is that the standard ford alarm light is flashing fast on the dashboard when the ignition is turned on... How can i bypass the standard immobiliser/alarm ? tryed unpluging the grey box in the drivers footwell but still the same problem!!
PLEASE HELP
Thanks
Matt
PLEASE HELP
Thanks
Matt
it is no longer fitted with a transponder in the key.. never had one in since i have owned it !! the doors have not been locked by a key either..
how do you bypass the key transponder ( so i can check this is still ok)
Thanks for your help people
have you tried drinking alot of lager and having another go in the morning
, when it happened to my tranny it ended up getting trailered back to ford, soz mate
I know wot your saying pal... I brought it back from work on the low loader now the bloody thing is stuck in the garage and wont run...
I like the idea about the beers though
everything seems better after some lager!!
right.... found out what it is....
I have been driving the car for the last 18 months
with a plain key (no chip in the key due to being bypassed before i owned the car when an alarm was fitted). Today it decides it wants to read a chipped key again!!
why is this? and also how would they have bypassed the chip?
I only found this out because i tried my spare key (still a plain one) and this one (the old door key) was next to it... so now i have to put the ignition key in and wave the old door key around the barrel
why is this? and also how would they have bypassed the chip? I only found this out because i tried my spare key (still a plain one) and this one (the old door key) was next to it... so now i have to put the ignition key in and wave the old door key around the barrel
If so ,"pats"is in the ecu then.
How did they disable it ,stick the transponder to the pick up for the key?
Thats on the ignition barrel under the s/column cowl.
Have you got any other pats keys for the car?
puddy
puddy
dont know how they disabled it!! all I know is I now have to carry 2 keys and waft one of em round the other
ffs..... gotta get it bypassed properly or get another key cut with a chip in...
ffs..... gotta get it bypassed properly or get another key cut with a chip in... Thread
Kiran1600E
11
Oct 2, 2015 11:35 AM
if I cant go out later...
