is this right?
Old Feb 2, 2006 | 08:52 PM
JezSierra's Avatar
JezSierra
happy with that
Default is this right?
i might be getting a sierra saff ghia 4x4,and was told that saff cos suspension was the same on these models,is this right?as i will be looking to uprate the suspension,lowering springs ect,wots the best ride height for a 4x4 with lowering springs ect,ect
cheers people
Old Feb 2, 2006 | 08:57 PM
xr4x4rs's Avatar
xr4x4rs
well i have cos suspension on my xr4x4 and went in no probs and id imagine the hubs are the same as mine
cosy hubs are different but not where the shocks are mounted
id say 30mm on a 4wd but mine is around 60mm and had no probs
Old Feb 3, 2006 | 05:41 AM
JezSierra's Avatar
JezSierra
happy with that
cheers rich
Old Feb 3, 2006 | 08:58 AM
Graceland's Avatar
Graceland
Team HOTHOT!
the front dampers are the same as are the rear dampers, the hubs however, are different - the only thing they have in common is the 4x4 sierras had thicker front dampers
Old Feb 3, 2006 | 03:32 PM
JezSierra's Avatar
JezSierra
happy with that
can you fit cosworth 4x4 setup to the sierra ghia 4x4?meaning hubs breaks shocks springs ect,ect?
and how much would it all cost?roughly?
Old Feb 3, 2006 | 04:11 PM
xr4x4rs's Avatar
xr4x4rs
yes you can mate
you can fit the cosy hubs straight on u will have to use cosy brakes aswell
