removing rear hub on fiesta si ?
and in answer to question, jack car up, chock wheels, remove roadwheel, release handbrake, undo big nut on hub, smack drum with hammer a couple of times, slide drum off
the bearings are encased one in the drum and one on the stub axle
remove the big nut in the middle of the drum, then with the handbrake off slide the drum over the rear brake shoes, can be bit of a c*nt so use a mallet.
with the drum on a bench/vice lever out the dust seal, then tap out the bearings with a screw driver but dont fuck up the mating surfaces
turn drum over and do that side.
to push new bearings in, use and old one and big bit of tube to drive in square, then tap out the old bearing, do the same on the other side
gease up the bearing races and insert it into the inner bearing and put the new dust seal in
adjust the rear brake shoes by using a screw driver to release the pawl and move the shoes together a bit
refit the drum to the hub
then fit the outer bearing race and big washer
then stick the new nut on and hang off the torque wrench to tighten, needs to be 290N/M iirc
put whell back on and pump the brakes a few times to re adjust them.
jobs a goodun
jobs a goodun
jessie_rs
11
Jun 3, 2019 04:57 PM
Oct 9, 2015 07:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
