What remote ISCV for ALS?
Old Feb 2, 2006 | 11:15 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default What remote ISCV for ALS?
need a biggun lol
whats out there thats good enough?
Old Feb 2, 2006 | 11:22 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Told you this already
Use the Mountune/WRC/GrpA/whatever you wanna call it ALS valve, and need a remote housing to bolt it to, just NOT the piddly lil thing they fit ISCVs to on some RS Turbos etc.
Gareth EscCos made a decent one IIRC
Bearing in mind you on throttle bodies you will need a custom one with more outlets, unless you just want to split the 1 big pipe into 4?
Old Feb 2, 2006 | 11:25 AM
He's on bodies?
Didnt know that.
Interesting stuff.
As for the valve, the vauxhall astra gte 16v ISCV are quite popular as ALS valves, and are readily available secondhand.
Old Feb 2, 2006 | 11:30 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
steve, i cant remeber you saying that
chip, cool, ill look into it.
as for bodies, well if you got a feb issue of FF turn to page 23, i have a lovely set of titan motorsport roller barrel throttle bodies and the inlet pictured.
as for the ISCV i guess i will have to mod it into 4 outlets for each port, but is shouldnt be too much of a problem
any pics of the one gareth has done?
Old Feb 2, 2006 | 11:31 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
this is the roller barrels
http://www.titan-motorsport.com/inletsystems.html
Stavros's Avatar
Stavros
DEYTUKURJERBS
Proper ALS valve like this with the whole valve moving up n down that middle spindle...
Rather than a gay modded version of the standard one, which is this...
Where the air goes thru the hole in the bottom and out that tiny hole you can see (closed in the pic) on the right.
Unless you just want loads of pops n bangs with no real efffect.
Old Feb 2, 2006 | 11:34 AM
You blagging bastard, nice one
doubt it will do much for performance in reality, but certiainly give you a massive amount of pub horsepower
Shame to waste them on a turbo though really
Fudgey's Avatar
Fudgey
Baby Cheesus
cool, cheers steve
Old Feb 2, 2006 | 11:35 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
most definatly
ah well, they look shit hot tho
Old Feb 2, 2006 | 11:48 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
I thought that, but MartinH said to me the other day it makes a massive difference to drivability in his experience.
Suprised me a lot, obv there a theoretical throttle responce advantage, but didnt think itd do much youd feel on a turbo motor.
Old Feb 2, 2006 | 11:50 AM
Im not convinced there would be much difference on a basic spec motor, but if martin says different then fair enough, be a silly man who didnt take notice of something martin says
Old Feb 2, 2006 | 11:54 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Its a pisser for me if he is right as ive gone from 6x throttle bodies to a 100mm throttle and the biggest fucking plenumn youve ever seen
Old Feb 2, 2006 | 11:56 AM
Ive still got the choice on mine, the inlet is currently being made as we speak, but ive also got a set of TBs knocking around with a plenum that i could use instead, although they are normal butterfly ones not sexy barrel ones!
Old Feb 2, 2006 | 12:02 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i still need to get a plenum fabricated for mine too.
but thats not a priority at the mo, building the bloody engine is lol
Old Feb 2, 2006 | 01:41 PM
GARETH T's Avatar
GARETH T
get on the lathe/mill
Old Feb 2, 2006 | 02:25 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers gareth, you got any drawings of it?
i can get me old man to knock it up piece of piss, but he will want some dimentions
also what valve have you used?
the mountune one?
Old Feb 2, 2006 | 04:07 PM
GARETH T's Avatar
GARETH T
sorry mate,,, no drawings,, i done it a long time ago now
the valve was of my own design,, and being honest i would do it different next time
Old Feb 2, 2006 | 04:17 PM
foreigneRS's Avatar
foreigneRS
Testing the future
what you've ended up with there gareth is not much different to the vauxhall one that chip mentioned. although it's smart, it hardly seems worthwhile
Old Feb 2, 2006 | 04:47 PM
GARETH T's Avatar
GARETH T
it can by-pass a massive amount of air though
and i got paid too make it
Old Feb 3, 2006 | 07:29 AM
foreigneRS's Avatar
foreigneRS
Testing the future
that's the best way
i'm now going to get paid to lay a thick brown cable
Old Feb 3, 2006 | 01:27 PM
GARETH T's Avatar
GARETH T
what your going for a poo
Old Feb 3, 2006 | 02:00 PM
foreigneRS's Avatar
foreigneRS
Testing the future
good one it was too
Old Feb 3, 2006 | 03:47 PM
Alloy's Avatar
Alloy
While we're on the subject, what is Mountune's EGR system?
I know it remove's lag, but is it an ALS as we know it, or is it another method of producing instant boost?
Old Feb 3, 2006 | 03:50 PM
GARETH T's Avatar
GARETH T
think how a gas turbine engine works, and you will be close
Old Feb 3, 2006 | 03:57 PM
Alloy's Avatar
Alloy
So is it like a mini gas turbine using pressurised air to spin the turbo?
Is it better than traditional ALS - in your opinion of course?
Seem's good to me, but I haven't heard of anyone using it.
Old Feb 3, 2006 | 04:02 PM
GARETH T's Avatar
GARETH T
works very well,, you need an ecu that can control it (pectel t6 and the likes)
it turns the turbo into a gas turbine
Old Feb 3, 2006 | 04:05 PM
Alloy's Avatar
Alloy
What other mod's does it need to work Gareth, or is it a one off bolt on item?
Sorry for my question's, but I just like to find new thing's out.
I appreciate the help though.
Old Feb 3, 2006 | 04:11 PM
GARETH T's Avatar
GARETH T
you need a als egr kit from mountune (this can be make,, but i havent made one yet so i wont list how too do it,, till ive tried myself0
WRC EGR system Ref: C877
EGR system (for WRC engines) provides instant throttle response by completely removing turbo lag. Positive boost levels are maintained even when the throttle is closed. Turbo temperatures are also reduced thereby increasing turbo life.
Price: Ł2,772.44 (Excluding: VAT at 17.5%, delivery and shipping)
you still need an als valve, and throttle body
ALS idle valve Ref: C615
Modified idle control valve to run Anti Lag.
Price: Ł382.33 (Excluding: VAT at 17.5%, delivery and shipping)
you need the egr too be fitted,, which is simple
you also need a pectel t6 2000 ecu,,, Ł2100 plus vat, wiring loom to suit Ł600
umm think thats about it,,, sounds a deal really doesnt it
Old Feb 3, 2006 | 04:15 PM
Alloy's Avatar
Alloy
Cheap as chip's.
Silly question, there'd be no need for air injector's with this would there? And what about the remote iscv too?
Sorry if that's a rediculous question G, but I'm trying hard to learn as much as possible.
Old Feb 3, 2006 | 04:18 PM
GARETH T's Avatar
GARETH T
you would still use air to air boost control,, as egr als only works off throttle, and boost control is on throttle
you dont have too use a remote iscv ever on a cossie
Old Feb 3, 2006 | 04:19 PM
GARETH T's Avatar
GARETH T
fire away mate,,
Old Feb 3, 2006 | 04:21 PM
Alloy's Avatar
Alloy
So, what is the purpose of having a remote iscv then, is it just a mod to make the car run smoother on idle or something?
Cheer's Gareth, much appreciated mate, really is.
Old Feb 3, 2006 | 04:26 PM
GARETH T's Avatar
GARETH T
when you cant use a throttle body with a built in ISCV, like throttle bodys or maybe a homemade rs500 type inlet,, when the iscv would block the second fuel rail
or even on a pectel t6 car when you could have both an ISCV and an ALS valve
Old Feb 3, 2006 | 04:30 PM
Alloy's Avatar
Alloy
Ah, now I see Gareth, thank's for taking the time to explain.
How do you know so much stuff mate? By reading or something? You seem to know a bit about almost anything lol.
Old Feb 3, 2006 | 04:34 PM
GARETH T's Avatar
GARETH T
insomnia
Old Feb 3, 2006 | 04:38 PM
Alloy's Avatar
Alloy
I wish I had insomnia lol, well, I get really anxious which keep's me awake, maybe I should buy some useful book's and make the most of the time it keep's me up hehe.
Thank's again mate.
Old Feb 3, 2006 | 04:40 PM
GARETH T's Avatar
GARETH T
btw i dont know much about much
Old Feb 3, 2006 | 04:43 PM
Alloy's Avatar
Alloy
Stop being moddest lol.
Old Feb 3, 2006 | 04:52 PM
GARETH T's Avatar
GARETH T
no im serious
Old Feb 3, 2006 | 05:01 PM
no im serious
I will agree he being serious
The other ALS valve Group A apparently...
