removeing ABS
right this has probly been asked a million time but whats needed to remove it i already have the engine and box out of the car all the abs pumps and line and have removed the pipe that run to the rear as they were ready for changeing but whats needed when i build it back up please ???????
Basically all u will need in terms of parts are some copper brake lines to connect up the pipes on the car that would of been connected to the modulators. OR if it was me i'd get some pipes off a NON ABS car as i dont like the look of home made pipes
(PS im a fussy git)
(PS im a fussy git)
Originally Posted by Trev
do you need to change the master cylinder ? an xr3i one has four break pipes coming from it while the RS one only has two.
what do peeps do?
TRev
what do peeps do?
TRev
