RS 500 Alternator Drop Bracket more dumb questions !!
Old Jul 21, 2004 | 11:16 AM
Tony Ryan's Avatar
Tony Ryan
Default RS 500 Alternator Drop Bracket more dumb questions !!
Ok , fitted a nice shiny original drop bracket , courtesy of Mr Storey
and now the metal adjusting strap has the wrong curvature and the fan belts are too short !! Was there a "right " strap and belts for the 500 , has anyone got this , and the correct length of belts so i can get some new ones ?
Cheers in advance
Old Jul 21, 2004 | 11:18 AM
RichardPON's Avatar
RichardPON
Now now Tony - there's no need to be calling them fan belts
Phil's Avatar
Phil
Jeebus
My old saph had a standard one on I think! Seemed to work fine??
Old Jul 21, 2004 | 11:19 AM
Tony Ryan's Avatar
Tony Ryan
lol , Fanny belts then Rich
Old Jul 21, 2004 | 11:24 AM
Tony Ryan's Avatar
Tony Ryan
Maybe ive got it on wrong then , the strap is behind the alternator , where was yours in front or behind , my one is catching on the top of the alternator and not letting it sit properly in line with the bolt hole that adjusts it ??
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
If I remember correctly, you can still use your existing strap, but you do need a longer belt.
Old Jul 21, 2004 | 11:37 AM
Ima-Racing500's Avatar
Ima-Racing500
You can use the original strap...i did and i used the std fan belts...must admit it was a bit tight but worked fine.
Old Jul 21, 2004 | 11:53 AM
turbinator's Avatar
turbinator
we just chop off the turbo to intercooler inlet... turn it 180 degrees and weld it on again .. no need for stupid brackets
Old Jul 21, 2004 | 12:06 PM
3drstretch's Avatar
3drstretch
Have you got the tensioning arm on the right way round.
When i did mine i used my standard belt and arm and so did 3 of my mates who all did the same.
Old Jul 21, 2004 | 12:24 PM
SPADGE's Avatar
SPADGE
Tony it should look like this
Old Jul 21, 2004 | 12:28 PM
3drstretch's Avatar
3drstretch
Tony= On Spadge's pic above i believe that to be a geniune 500 tensioning arm.If you use the standard 1 you will find that where the bolt tighten's it will be to the extreme right if the hole.As you look at it.
jonfoc
16
Sep 11, 2018 05:35 PM
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
cossie09
Sep 10, 2015 06:56 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
