Faulty ECU????
Old Jan 30, 2006 | 09:01 AM
Danny-p's Avatar
Danny-p
Default Faulty ECU????
Quick question about my small turbo escoss. i'm doing the head gasket at the moment but just before i brought it into the garage i couldnt help but noticing that when i come up to traffic lights and put the clutch in the car revs go right down (below 1000RPM) then up again. it does it about twice then starts to idel fine again. it only seems to do it when it gets walm and ive bootes it. if i drive it round just tickling it (not bringing it on boost) it seems to be fine till walm. Could it be the fact that the head gasket was on its way out or could it be a faulty ECU
Any help Would be appriciated
Thanks
Old Jan 30, 2006 | 11:19 AM
Richie Russ's Avatar
Richie Russ
Wouldnt have thought it would be your ECU, with the head gasket problems you are having it could be related, maybe check the idle control valve for starters.
Old Jan 30, 2006 | 02:28 PM
rizla's Avatar
rizla
Just a guess what about the Lambda sensor
Old Jan 30, 2006 | 02:35 PM
Danny-p's Avatar
Danny-p
i've checked the idel control valve i'll check the lambda sensor tomoz thanks
Old Jan 30, 2006 | 03:46 PM
bam's Avatar
bam
give the trottle body a good clean .
Old Jan 31, 2006 | 10:43 AM
sailorbob's Avatar
sailorbob
Get a code reader on the ecu, it might save you hours of fruitless checking.
Old Jan 31, 2006 | 11:38 AM
auralisRS's Avatar
auralisRS
Mine does exactly the same as yours, exactly. Mine has just had a strip down including head gasket, mine actually stalls too...starts fine straight away. It never used to do this. The revs do the same as you, idles fine, then when you come to a rest at lights or something, it goes to abou 200rpm , then up...
IF you find the fault do let me know...cheers.
Old Jan 31, 2006 | 07:02 PM
Danny-p's Avatar
Danny-p
Default Anyone
There must be someone who knows on here!!
Old Jan 31, 2006 | 07:18 PM
sailorbob's Avatar
sailorbob
The trouble is it could be any one of couple of dozen things causing the problem, hence my recommendation to get a code reader on it. Any modifications to the car?
Old Feb 1, 2006 | 08:53 AM
Danny-p's Avatar
Danny-p
sailorbob
Stage 1 but it only started doing it when i first got it i started to mess around as you do and took the air filter off to see if my old air filter would go on. then when i put it back together it started doiung it
Old Feb 1, 2006 | 08:57 AM
Richie Russ
Originally Posted by Danny-p
sailorbob
So what filter is on there now, the original or a new one ? maybe you have knocked a pipe or the air filter isnt on properly ?
Old Feb 1, 2006 | 09:23 AM
Danny-p's Avatar
Danny-p
Richie Russ
THE ORIGINAL FILTER IS ON IT AND ALL BACK TO HOW IT WAS. A RIGHT MISTERY
Old Feb 1, 2006 | 09:26 AM
Richie Russ
You must have disturbed something though whilst you were doing it, the only thing i would do is take it somewhere for a once over if you have checked all the 'simple' things ?
Old Feb 1, 2006 | 09:31 AM
Danny-p's Avatar
Danny-p
can u suggest anything to check
Old Feb 1, 2006 | 09:36 AM
Richie Russ
How irratic is it ?
Oh and i know someone with some cossie wheels / tyres if you're interested.
Old Feb 1, 2006 | 09:46 AM
Danny-p's Avatar
Danny-p
very!
Do they wanna swap are they mint and any pictures of them
Old Feb 1, 2006 | 09:49 AM
Richie Russ
Danny you have pm.
I think your best bet is to take it to someone for them to look at, hows your wiring out of interest ?
Old Feb 1, 2006 | 09:52 AM
Danny-p's Avatar
Danny-p
the wiring is fine
alll i want to do is get my car running right, put it back to standard then sell it
Old Feb 1, 2006 | 09:58 AM
Richie Russ
Sounds to me like an air leak somewhere.
Old Feb 1, 2006 | 10:05 AM
Danny-p's Avatar
Danny-p
to be honest when taking the inlet off the head i noticed that the gasket looked a bit black rond one of the inlets and the rest looked alright
Old Feb 2, 2006 | 01:11 PM
Danny-p's Avatar
Danny-p
got it all back together but now when the car is walm and been driven for 5 mins the reves are going up then down then up then down and so on
any ideas
Old Feb 2, 2006 | 02:59 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Well if it turns out to be the ECU, I have the one that came out of my car going cheap .
Old Feb 9, 2006 | 12:12 AM
The_turbo_doc's Avatar
The_turbo_doc
TRY CHECKING YOUR TYRE PRESSERS PAL IF FAILING THAT WE CAN SORT IT FOR 30 GRAND
Old Feb 9, 2006 | 10:14 AM
Azrael's Avatar
Azrael
It can be related to VSS sensor - EEC -IV has no working idling procedures if that sensor is faulty. I had this problem on mine.
Old Feb 9, 2006 | 06:27 PM
Danny-p's Avatar
Danny-p
in english please mate
Old Feb 9, 2006 | 06:35 PM
sailorbob's Avatar
sailorbob
VSS = vehicle speed sensor
Old Feb 9, 2006 | 06:36 PM
Danny-p's Avatar
Danny-p
wheres this situated mate
Old Feb 9, 2006 | 07:07 PM
Azrael's Avatar
Azrael
It's english mate!!
Old Feb 9, 2006 | 07:08 PM
Azrael's Avatar
Azrael
On the crosshaft that goes through sump. It's on the left hand side of the car and speedo cable goes into it it actually drives the speedo cable.
Old Feb 9, 2006 | 07:10 PM
sailorbob's Avatar
sailorbob
IIRC it's where the speedo cable comes out of the gearbox.
Old Feb 9, 2006 | 07:23 PM
Azrael's Avatar
Azrael
Not exactly the gearbox...
Old Feb 10, 2006 | 09:11 AM
sailorbob's Avatar
sailorbob
Yeah, maybe I should have put IIRI (if I recall incorrectly)
Old Feb 12, 2006 | 11:38 AM
Stu @ M Developments's Avatar
PassionFords Creator
1st option is a leaking dump valve.
2nd option is a failed VSS.
3rd option is a laeking inlet gasket.
4th option is a failing AFM.
5th option is a fault in the ecu.
continue in this fashion till doomsday... lol
Old Feb 12, 2006 | 01:53 PM
Danny-p's Avatar
Danny-p
cheers stu
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
