General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Mate has a 52 plate Focus ST170 and it's using an alarming amount of brake fluid. Had a rummage under the car just now and aprt from a bit of goo on th ebrake pipe I can't see anything too untoward.
lol, i reckon he should get it checked out asap. clutch slave cylinder is probably whats leaking though. this is in the gearbox on the ST170 iirc soo check for fluid leaking out the bottom of the box.
replace clutch pipe from master to slave they always go .....part is 1bout 26 quid i think dont loose the 2 clips ...bit of a bugger to rebleed just take your time
Yeah i would have suggested the clutch master cylinder. Not hear of any problems with them, but if the fluid isnt being lost from the brakes then could be the clutch cylinder
