Cam choice???
my follwers are getting proper rattley now and are starting to piss me off.lol. wot i wanna know is that if i put a piper 285t2 (14psi+) in will it run ok wit my car due to it holding 12psi and only spiking to 14 i dont see the point in putting the lower spec one in cos if i want more power later on the cam would be right if ya know wot i mean lol
CheeRS
Craig
NYRSOC
CheeRS
Craig
NYRSOC
With so low boost I'll definately vote for the std. cam. You'll achieve more dynamic compression with it suiting your boost level. You'll lose ~5hp only high up at the peak, but you'll gain around 700 rpm in power band. Also only costs a fraction.
