camber ?
Old Jan 28, 2006 | 02:39 PM
LEE-RS's Avatar
LEE-RS
Custom
Default camber ?
just took my back wheels off and there wearing out the inside of the tyre i know you can get adjustable tca's for the front but what can you do with the back ?
Old Jan 28, 2006 | 02:48 PM
NUTS RuS's Avatar
NUTS RuS
Cheat by elongating the hole where the inner wishbone bolts to
Old Jan 28, 2006 | 03:00 PM
S1's Avatar
S1
Its on an S2 i assume? If so then where the hub bolts to the damper, there is a certain amount of adjustability. If you need more movement than you can file out the holes in the damper until you get is right.
Old Jan 28, 2006 | 03:02 PM
Oranoco's Avatar
Oranoco
How low is the car?
I have only worn out 3 sets of back tyres since having my S2 and that's 10 years. Wish I could say the same about the front
Old Jan 28, 2006 | 03:16 PM
LEE-RS's Avatar
LEE-RS
Custom
yes for a s2 its been lowerd about 60 mm so i just drill the hole to give me abit of adjustability good idea
Old Jan 28, 2006 | 03:18 PM
Oranoco's Avatar
Oranoco
60mm really is too much of a drop mate. You'd be far better off with a 30mm drop as well as stopping you killing tyres so quickly it will improve teh handling no end as well
Old Jan 28, 2006 | 03:27 PM
LEE-RS's Avatar
LEE-RS
Custom
was lowerd like it when i bought it tho i have done about say 4000 miles on them and there just started to show abit of wear on the inside edge so not to bad unlike the fronts
Marc sierra
12
Aug 30, 2015 10:38 AM
track.focus'd
Aug 12, 2015 05:53 PM
xrsi
Nov 14, 2005 10:48 PM
DaveEscos
Oct 29, 2005 12:42 AM
Dan@Rapid-Ford
Jul 16, 2004 03:22 PM
