Bailey Header Tank
Just bought a bailey header tank. At the moment, I have a standard header tank with a braided hose going from the top of the tank to the top of the swirl pot.
Can I just use any hose between the swirl pot and header tank, like a normal vacuum hose or does it have to be a samco water hose or similar?? Is this just some sort of over flow??
Im not quite sure how swirl pots actually work and what they do??
Thanks in advance.
Thanks in advance.
