Cossie rev limiter
Old Jan 28, 2006 | 08:44 AM
KSA-Cossie's Avatar
KSA-Cossie
Default Cossie rev limiter
Is it ill advised to hit the limiter on standard valves etc ?
Old Jan 28, 2006 | 08:52 AM
Rhys's Avatar
Rhys
Its never ideal to, but cant harm it if every now and then. Though if it happens a lot you can pity the pistons.
Old Jan 28, 2006 | 08:55 AM
KSA-Cossie's Avatar
KSA-Cossie
Thanks rhys.
Old Jan 28, 2006 | 09:27 AM
bud-weis's Avatar
bud-weis
Football Cwazy
what's your limiter set to? mines at 7200 now on standard valves/valve springs. i think to go further than that then double vavle springs at least would be needed
Old Jan 28, 2006 | 09:31 AM
KSA-Cossie's Avatar
KSA-Cossie
How is it altered ?
Old Jan 28, 2006 | 10:24 AM
Rhys's Avatar
Rhys
ECU, with programming the limiter, if you have a chip it might be altered!
Old Jan 28, 2006 | 10:38 AM
KSA-Cossie's Avatar
KSA-Cossie
I'ts chipped to stage 3,so does that mean it will be raised slightly ?
Old Jan 28, 2006 | 10:49 AM
rapidcossie's Avatar
rapidcossie
rev limit has more to do with what the rods will handle than the valves.
if the timing is done correctly the valves shouldnt really hit the pistons.
have heard of it before tho.....
i have massive pockets in pistons to make sure they dont come into contact.
Old Jan 28, 2006 | 10:51 AM
KSA-Cossie's Avatar
KSA-Cossie
Cheers euan never really go near the redline anyway will do when it's been set up properly.
Old Jan 28, 2006 | 10:59 AM
rapidcossie
when you put your car on the rollers you will see where your peak power is made...
on standard cams its about 6.5k i think. no point really revning any further than that mate.
you be at the pf meet??
Old Jan 28, 2006 | 11:23 AM
KSA-Cossie's Avatar
KSA-Cossie
Yeah gonna be there.
Old Jan 28, 2006 | 11:28 AM
rapidcossie
good stuff
Old Jan 28, 2006 | 04:13 PM
Rhys's Avatar
Rhys
AS you can see the little pits on my piston by all accounts is common problem where its reved hard and on limiter where valves meet piston.
only what i have been told though.
Old Jan 28, 2006 | 04:17 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i'd have thought the pitting was from det, the valve contact is much clearer on there, at about 8 o'clock (clock scale )
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
SMILER258
Sep 28, 2015 09:04 AM
cossie330
Sep 27, 2015 04:13 PM
