rs500 intercooler in a s1
Jan 28, 2006 | 06:25 AM
anyone off here done it?
any pics? would like to know what was needed to do? cutting or brackets made
sure i seen someone off here with it
Jan 28, 2006 | 06:59 AM
Jan 28, 2006 | 07:09 AM
Jan 28, 2006 | 07:18 AM
Jan 28, 2006 | 03:03 PM
Looks good but how does the radiator fit? Would be very close to the turbo?
Jan 28, 2006 | 03:19 PM
seen a D reg S1 in PF mag with one
Jan 28, 2006 | 03:32 PM
Your Inlet is on the wrong side...
Jan 28, 2006 | 04:11 PM
ha ha its me new secret spec rads
things have now changed
Jan 28, 2006 | 04:13 PM
Quote:
Originally Posted by T28 RST
mint!
Jan 28, 2006 | 04:27 PM
Good good... What you doing with your inlet then ?
Jan 28, 2006 | 05:08 PM
inlet stays
everything else is going
only had it on the road for a day
really should leave it alone for a while
Jan 28, 2006 | 05:24 PM
whats gone wrong now m8?
Also how much is an inlet like yours bythe way?
Jan 28, 2006 | 05:34 PM
Benn... He just cant stop spending
Jan 28, 2006 | 05:41 PM
Jan 28, 2006 | 05:47 PM
Gus I've a 500 IC on my S2 water temps were a little high from heat soak after a good thrash, however two S2 fans sorted the problem out.
ACT are well low though
Jan 28, 2006 | 06:26 PM
Got pics of your engine bay as it is now gus?
Jan 28, 2006 | 07:00 PM
B8 did it need any mods to fit?
i will have plentgy of room so heta soak will hopefully not be a problem
as you say thou easily rectified
no pics as yet, its just a big hole at the minute
engine is stripped to bare block
again
Jan 29, 2006 | 05:11 PM
Gus I dont have any pics as I recently lost a HardDrive full of pics etc
I had this on my photobucket account hope this helps.
Old pic with 1 fan in place
The S2 needs a whole load more work caried out to have 1 fitted than the S1 which is good news for you
Jan 29, 2006 | 05:35 PM
Feb 12, 2006 | 11:04 PM
what sort of work mate? take it slam panel needs butchering?
Feb 13, 2006 | 01:02 PM
im sure andy has a removeable s1 front panel,he'll confirm this if im right or not
Feb 14, 2006 | 07:18 PM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
