Where can I get a new turbo oil feed for a cossie?
Getting a new turbo fitted in next week or so and since the old one seized up want to put new oil feed / return pipes on at the same time.
Went to the local ford dealer today to order them, and was told they're no longer available!?
Presumably there are aftermarket ones available? Anyone know where I can get them from?
Boon
Boon
Originally Posted by boon
Cheers for replies guys.
Nightdavva, you sure the return isnt necessary to replace? How come the feed fails but return is ok?
The bore of the return is a lot bigger than the feed so it is less prone to getting clogged up and also is easier to clean out,you should be able to see down most of it with a torch,will prob not be too bad anyway...
You can get them made at a local hydraulics company like abbey hose etc.. for under £15
www.abbeyhose.co.uk
Regards
Jano
www.abbeyhose.co.uk
Regards
Jano
Originally Posted by Wes RS
http://search.ebay.co.uk/search/search.dll?sofocus=bs&sbrftog=1&fstype=1&from=R10& satitle=oil+feed+Sierra&sacat=-1%26catref%3DC6&bs=Search&sargn=-1%26saslc%3D3&sadis=200&fpos=PO30+5EA&ga10244=1042 5&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1&fsoo=1
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
