rs 500 cooler help
Old Jan 27, 2006 | 08:00 PM
a7fco's Avatar
a7fco
Default rs 500 cooler help
could someone please tell me what i need to fit 1 to my 3 door eg.
fitting kit[ seen 1 on ebay]
alt. drop bracket do i need 1 or not
and who stocks these
and it has the larger pipes on the cooler does someone make these pipes
cheeRS a7fco
Old Jan 27, 2006 | 08:51 PM
daz1968's Avatar
daz1968
If you fit a pro alloy or pace etc then if pipes correct size all you need are 2 bolts and rubber mountings same as on rad, all existing hoses fit fine, although if you need a dump valve then it requires a new hose with take off, if you mean a genuine cooler then you need mountings as above, and either some hoses designed to fit from 3" cooler to 2.5" throttle body and to T3 turbo, I think roose motorsport do them, or as I have done and use std 500 hoses, had a silicon hose sleeve made up fit to turbo from roose motorsport and had my throttle body sleeved up to 3" with alloy sleeve and bored out into a smooth cone inside, then I also needed the alternator drop bracket so that the 500 hose on turbo side missed the alternator, so as can be seen there are a number of ways to tackle it, but I have had a pace one and changed to a genuine one as it fits alot better, and have also used RS500 air inlet to direct the cool air from behind the grill into the airbox.
hope this helps
Darren
Old Jan 28, 2006 | 04:41 PM
a7fco's Avatar
a7fco
cheeRS daz1968
gcfcos
59
Oct 6, 2015 05:04 PM
