Denso spark plugs - Updated
Originally Posted by Stu @ M Developments
Never... You sure you measured em right?
i hate cars
But I thank you for taking the time to help
PassionFords Creator
0.4mm is the diameter of the Iridium tip in the center Kev, nowt to do with the gap., Hope you havent knackered em by levering on that tip....
i hate cars
bought some mats for the rear and there a completely different grey
HATE HATE HATE thanks again
bttt for stu so if ive been careful not to touch the tip I will be ok
do they usually come gapped then and just fit straight in then ??
****edited to add gonna ask simon for another set as im to scared to run em now there modified as other owners havent had to gap em and im too scared they will break now
i feelered them out the box and the gap was way smaller than 0.9 or 1.0mm i mean it was probably half that
I should of measured the exact amount but when 90 or 1mm wasnt near i just thought oh well fit em must be different
then when it ran ruff and stank so bad I removed em and posted this post
I dont understand it never ever had a prob with buying spark plugs before my honda had denso's and they were fine etc
i will await simons reply
deathrider666
Sep 28, 2015 06:12 PM
