Whats best? s1 or 1600i arb?
Old Jan 26, 2006 | 01:15 PM
Benn 304R's Avatar
Benn 304R
Default Whats best? s1 or 1600i arb?
As said, what is the best out of the 2 or are they the same?
cheers
Benn
Old Jan 26, 2006 | 01:58 PM
B.A.R's Avatar
B.A.R
Rs 1600i roll bars are better as far as i no, they got a thicker anti roll bar than the s1. as far as i no anyway
Old Jan 26, 2006 | 02:30 PM
andyt's Avatar
andyt
16 i
Old Jan 26, 2006 | 02:38 PM
Andy-R's Avatar
Andy-R
Benn I've got the aftermarket S1 lower arms(Adjustable) & 1600i tension struts but have done away with the ARB completely, only to be considerd if you plan on running coilovers and get the spring rate right.
hth
Old Jan 26, 2006 | 05:32 PM
BillyCabrio's Avatar
BillyCabrio
Best way to see is have a look at Tonys Rs fella, i think he has the Turbo Technics set-up
Simular to the Rs1600i version, i think.
Old Jan 26, 2006 | 05:45 PM
gus's Avatar
gus
i will be using bits of both
dont ask me how but tommy field saidn it will be good enough for me
i have the mef compression struts aswell
Old Jan 27, 2006 | 09:15 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Originally Posted by BillyCabrio
Best way to see is have a look at Tonys RS fella, i think he has the Turbo Technics set-up
Yeah I do, but that's like rocking horse shit. He won't need that because it's an S1, RSi version will be best, if you can get one.
Old Jan 27, 2006 | 09:31 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Remember the S1 ARB is thinner, but solid. The RS1600i ARB is thicker, but hollow.
Old Jan 28, 2006 | 01:24 AM
jonnyturbo's Avatar
jonnyturbo
i allways thought the 16i had double anti roll bars???
Old Jan 28, 2006 | 08:24 AM
Tony Turbo's Avatar
Tony Turbo
Certainly not.....
The one on the right is the RSi ARB set up
Old Jan 28, 2006 | 11:13 AM
BillyCabrio
So pretty much the same then? Would solid bars be as strong as hollow ones?
Originally Posted by Tony Turbo
Certainly not.....
Whats the one on the left then? As it dont have the gearbox mount hole?
Old Jan 28, 2006 | 11:14 AM
Tony Turbo's Avatar
Tony Turbo
That is Rocking Horse Shit
Better edit that photo actually......
Old Jan 28, 2006 | 11:19 AM
BillyCabrio
And the one you have
Old Jan 28, 2006 | 11:20 AM
Tony Turbo's Avatar
Tony Turbo
That wasn't the actual one, but yeah
Mine had been modified to take a larger diameter exhaust.... They must have known I would need to fit a 3" Mongoose
155lee
Oct 27, 2015 04:55 AM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
truffleshuffle
Sep 10, 2015 09:35 PM
chris m1
Sep 7, 2015 08:02 PM
