Fuel Metering units
Old Jan 26, 2006 | 10:18 AM
Damienholmes's Avatar
Damienholmes
Default Fuel Metering units
Is it me, or are these things the worst possible part on the car !
im fed up of buying 2nd hand ones that dont work, Do any of you guys know where i can buy a new one, or send mine to get refurbished and fixed.
Also some prices if you know any,
Thanks
Damien.
Old Jan 26, 2006 | 10:53 AM
COSSIE 1's Avatar
COSSIE 1
have u tried ford? it will cost u but it would be brand new
Old Jan 26, 2006 | 11:50 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
they are expensive, if your that fcuked off, it'd be cheeper to convert to EFI
Old Jan 26, 2006 | 01:19 PM
Damienholmes
ive thought about converting to efi, and id like to do that but ive looked into Oddkidds kit and im not to keen on parting with £2000 right now, as i dont have that sort of money to spare.
Would it be cheaper to buy the efi kit on its own bit by bit, i dont really know what it takes to convert the car, so if you got time could u make a list.
Old Jan 26, 2006 | 02:29 PM
Robliddle's Avatar
Robliddle
I agree mate, the meter units are a pain in the arse, im on my third one.
And i think its days are numbered. U can get the origional bosch units from ford but the bottom bit alone is over £800 and that does not include the top bit which all the red injection pipes fix to. I think the futre is omex or any other aftermarket engine managment. Sounds alot of money to lay out but buy the time u have finished buggering about with the the old bosch toss its well worth while. Plus u have Efi managment which has more scope for tuning.
Old Jan 26, 2006 | 02:46 PM
Damienholmes
What do you guys think is my cheapest EFI option
Old Jan 26, 2006 | 04:29 PM
Robliddle's Avatar
Robliddle
First have a look at your block some cvh turbo blocks have the hole already factory drilled for the crank position sensor if your lucky and it has this hole, u can use a fiesta Efi managment , u will need a conversion plate for the EFI manifold to fit the k-jectronic head. I think odd kid sells these plates and im pretty sure ive seen info on this conversion on his site. Was going to use this set up myself but my block is to old to have a cps hole. need to sort a cps sensor out.
Old Jan 26, 2006 | 04:59 PM
addiction's Avatar
addiction
Jamsport were doing Gotech managment for £949 fitted and mapped!!
Old Jan 27, 2006 | 10:14 AM
Robliddle's Avatar
Robliddle
WoW thats well cheaper than the omex set up i was looking at. The bits alone were about 1300 quid.
Old Jan 27, 2006 | 11:20 AM
Damienholmes
How good is the gotech, and whats included there ?
Old Jan 27, 2006 | 02:20 PM
JimmyBoy's Avatar
JimmyBoy
Your cheapest and easiest option I reckon is to go to ofab/ofac FRST management.
http://www.escortrsturbo.co.uk/forum...p?showforum=59
or go for megasquirt
http://www.escortrsturbo.co.uk/forum...howtopic=10711
or go cossie management
http://www.escortrsturbo.co.uk/forum...p?showforum=57
People are going to have different views on the above options, but they are all good viable options.
Old Jan 27, 2006 | 02:40 PM
Damienholmes
Wow thanks for that mate, that will provide some good reading material tongiht, Ill look into them all and see which one i will benifit from the most.
Old Jan 27, 2006 | 02:51 PM
JimmyBoy's Avatar
JimmyBoy
No probs dude. I know of people that have converted to the megasquirt system for less then £500 (thats an all in price - inc. vat.), and its a good system, fully mapable etc, take a read of my topic on there and make your mind up. Thats what im gonna go with anyway.
This topic should help you if you decide to go that route:
http://www.escortrsturbo.co.uk/forum...&hl=megasquirt
I am going to write a step-by-step installation guide, but just havent got off my arse to do it yet, but the above topic should more than help you out.
Also, this may be of help to you:
http://www.fiestaturbo.com/forums/vi...c.php?t=122386 / http://www.mtechautomotive.co.uk/
Hope that helps, and doesnt totally baffle you! lol
155lee
Oct 24, 2015 11:11 AM
Bransby
Sep 21, 2015 05:29 PM
rs_jim
Sep 19, 2015 08:41 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
