Cosworth YB Manual - Section Management - Ignition System
PART A - Engine, Engine Management and Turbocharger
2. Electronic Engine Management - The Ignition System
The Distributor
The distributor - make Marelli - is driven by the auxilliary shaft as on the standard OHC engine.
A Phase sensor, located opposite a cam having two teeth separated at 90° to each other, is fitted inside the distributor. At the passing of a tooth the sensor delivers a signal to the ECU. This signal is similar to the signal supplied by an RPM / TDC-*sensor fitted at the crankshaft pulley.
Both the signal from the distributor and the RPM / TDC-sensor enable the module to identify the phase of each cylinder. This information forms the basis on which the ECU module decides on spark timing and fuel injection.
The Ignition Coil and Ignition Module
The Motorcraft ignition coil and the ignition module (make Marelli) are both fitted to the left fender apron
The ECU sends a Spark-out (SPOUT) signal to the ignition module to trigger an HT pulse by switching the coil primary circuit off.
The Spark Plugs
The Sierra RS Cosworth is fitted with Motorcraft spark plugs AGPR 901 C.
Distributor
1 = Phase sensor
2 = Cam with two teeth
RPM / TDC-Sensor
1 = Tooth on crankshaft pulley
2 = Sensor
The Distributor
The Spark Plugs
Distributor
1 = Phase sensor
RPM / TDC-Sensor
2 = Sensor
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Aug 14, 2015 07:29 AM
