WHATS WRONG WITH MY RST
Old Jan 24, 2006 | 08:08 PM
Tonks's Avatar
Tonks
Default WHATS WRONG WITH MY RST
I did a service on my escort rst the weekend.
Changed oil, filte, fuel filter, dizzy cap, rotor arm, leads, plugs. Then now i cant get it to start. The leads are defo in the right order and the plugs are all good. WTF have i done wrong.
and i desperatly need it fixed
damn thing
Old Jan 24, 2006 | 08:15 PM
wrcwrc's Avatar
wrcwrc
Ok first easy things you can check are:-
Have you put the fuel filter on the right way (is the flow arrow in the right direction?)
Double check that the arm + cap are both secure.
Failing the above my money would be on the fact that you've disturbed something, probably a wire or soemthing.
Old Jan 25, 2006 | 10:06 AM
PaulT's Avatar
PaulT
You may need to bleed the fuel system as you have changed the filter causing air in the system. Crack the cold start valve nut on the metering head and crank the car for a few seconds and then nip it back up.
PaulT
Old Jan 25, 2006 | 12:00 PM
AJC's Avatar
AJC
PaulT
petrols dont get air locked i dont think
Old Jan 25, 2006 | 12:46 PM
16imarty's Avatar
16imarty
left dip stick out i did on my s1 and would not start lol
Old Jan 26, 2006 | 11:08 AM
PaulT's Avatar
PaulT
PaulT
Always bleed mine when changing the fuel filter, i have stood in the cold for hours scratching my head with this, the other way is to take the air filter off and press the plate down whilst cranking the car instant fuel at the injectors.
K jet relies on fuel pressure for the injectors to work unlike EFi where its pulsed electrically
Cheque book tuner?????
PaulT
Old Jan 26, 2006 | 05:22 PM
Tonks's Avatar
Tonks
is defo getting fuel as the new spark plugs are plastered in fuel. Could it be as it a new fuel filter it is now over fueling as the old on was on the car for at least 2 years. as the car stood for that period.
Jamie
Old Jan 26, 2006 | 05:47 PM
AJC's Avatar
AJC
Jamie
doubt it very much
Old Jan 26, 2006 | 06:03 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
always hold the meterhead flap down when starting after messing with the fuel system
always works for me
Old Jan 26, 2006 | 06:59 PM
HORNETS7's Avatar
HORNETS7
Jamie
has it got a spark then?
Old Jan 26, 2006 | 07:17 PM
Tonks's Avatar
Tonks
yes. defo. and fuel. it was running 1 hr earlier and now its dead
Old Jan 26, 2006 | 09:23 PM
Tonks's Avatar
Tonks
haha. you people are gonna piss yo pants.
i checked the battery as it wasnt dead but not perfect.
so i though i will charge it. and it starts. ha ha. i think i must of flooded it with so much fuel it wouldnt start so leaving it standing for a day must of cleared it
and now its alive and well ha ha.
i feel a propper c u next tuesday.
ohh well. 1st lesson of rs ownership learned lol
Old Jan 27, 2006 | 07:11 PM
James Raby's Avatar
James Raby
PaulT
PaulT
oooh, look slike we have a keyboard warior on our hands, sod bleeding it - it should start fine after a few primes of the fuel pump, most simplest way to do it
Old Jan 27, 2006 | 07:32 PM
PaulT's Avatar
PaulT
No keyboard warrior here Mr Raby just trying to help out if i can i note your post well down the list and sarcastic at that another cheque book tuner dare i ask ???
Old Jan 27, 2006 | 07:40 PM
James Raby's Avatar
James Raby
me sarcastic - never
I used to be a cheque book tuner, or cash deals
Sod that now, if I can learn and save a few pennies - I'll damn well have a go at it
Old Jan 27, 2006 | 08:19 PM
PaulT's Avatar
PaulT
is that Rudeys old car in your sig?
Old Jan 27, 2006 | 08:40 PM
James Raby's Avatar
James Raby
Dead and buried long time ago, this cars been alive ince 1999
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
