BIG Spec RS Cosworth 400BHP+ SOLD!!!
This is my mates pride and joy, this vehicle is QUICK!!
all it would need is a map, and a parachute to slow the thing
Engine:
Low comp pistons
Group A touring car Head from A1 rally Sport
Proper T35 with 0.63 exhaust housing done less that 1000miles
Mongoose system
Grey injectors
3 bar map sensor
RS500 intercooler
Cone air filter
Standard camshafts
Full set of Samco’s
Powder Coated Rocker cover
Swirl pot included but not fitted
Bailey header tank
Bailey breather kit
Bailey power steering tank
OMP strut brace
Bayjoo chip set up for Greys and 30psi
Currently does peak at 30psi then holds on 28psi all the way through
Should push good power but can be even better with a Map, was originally going to go A1 rally sport but my mate has no time
Chassis:
Standard 4 pots with drilled discs
Avo Coilovers with full adjustments
17 inch RS 7 spokes with good tyres etc
Exterior:
Flint grey
Morretes
4x4 bonnet
Interior:
Full raven leather interior with minimum wear
Autometer boost and volt gauges
Rare 4 spoke RS steering wheel
There is only a couple of discrepancies There is a deep scratch where some PRICK has caused it on the passenger door about 10 cm in length and a scratch in the passenger wing – due to jealous wankers again!
You know what a big spec saf goes for these days so its up for DECENT offers no timewasters or bullshiters or test pilots, no money or insurance then no drive
Contact me on here or via PM and il give you my number, car is in slough Berkshire ready to veiw
thanks for looking
all it would need is a map, and a parachute to slow the thing Engine:
Low comp pistons
Mongoose system
Grey injectors
3 bar map sensor
RS500 intercooler
Cone air filter
Standard camshafts
Full set of Samco’s
Bailey header tank
Bailey breather kit
OMP strut brace
Chassis:
Exterior:
Flint grey
Morretes
4x4 bonnet
Interior:
thanks for looking
:gayflag:
unchballs:
