Kicker ZR600 BIG Amplifier for sale
As above, i've decided to sell it due to upgrade. Its given me 3 years of pumping power, and has never let me down. I've had it serviced recently by Kicker who found it faultless. It also comes with an extra plug in module allowing you to adjust the bass / frequency from your dash! (this extra cost me £50 alone!). The amp cost me £600 and the service was £60.
Im asking £300 for it. Its all boxed with instructions/packaging etc...
power output is 150w x 2 @ 4ohm, 300 x 2 @ 2 ohm, and can run 2ohm stable mono @600w rms. Remember these are yankee amps so power is ALWAYS more than stated. I've run 2 Kicker Solobarics from this without a problem, and have been running 2 JL W3 dual 2ohm coil subs from it currently.
See here for a full spec:
http://www.crutchfield.com/S-JD9Ajpn...110#morephotos
Ideally i dont really want to part with it until September (abotu 2 months), but will for a quick sale. A £100 deposit will secure the amp until then.
Chris
Chris
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
