wanted escort rs turbo
hi peeps
looking for a clean 200bhp plus escort rs turbo in any colour
must be in good nick no dogs service history also a plus
email pics at piperbigguns@aol.com
iv got a 87e s2, full blue printed engine rebuild by power engineering 16,000 miles on it since 1997 receipt an stamp 2 prove,mint interior little tlc on ex, full s/s scorpion ex,3 spoke rs steering wheel, mot til mid 06,no tax due 2 being sorn off the road, garaged for last 5 months, loads ov receipt and history! it needs a -31 and it should b running between 180-200 bhp, when cold it doesnt like going into third but once warm its fine, i think its where its been sitting for 5-6 months because my mate cos done the same, but now thats fine,the paint works fine,might need a blow over or a very good t-cut as its a slight diff shade on the passengers rear quarter like most merc grey rs's! little crack in front bumper where the bloke had it b4 and caught it on a curb cumming out of his drive! thats about it, got loads of prints outs and graphs from power engineering to prove,loads of receipts and history! reason im selling got a series 1!
let me no
let me no
check my mates one out you wont be dissapointed
http://atsearch.autotrader.co.uk/WWW...00604222496114
ford escort rs turbo 1989 model
subaru mica blue
full leather interior including door cards with rear bench arm rest and head rests (rare)
17" momo arrwo alloys
spax lowering kit, 1999 (with recipt)
full mongoose exhaust 27/06/98 (with recipt)
group A twin piston dumpvalve (with recipt)
standard air box with k&n panel filter (rare)
new (100 miles ago) piper 285t2 high boost kit and vernier pully with recipt
rolling roaded at 161@wheels @ 1bar with more to gain with good set up
new -31 garret actuator with reciept (100 miles ago)
Superchips chipped ecu
drilled and grooved black dimond brakes and pads (with recipt)
90 spec spoiler
de-locked
cat1 cobra 7928 alarm with certificate
new piston rings, cylinder head gasket, bolts, pistons & con rods with reciept 1999
new timing belt (ford reciept 28/06/05)
new starter motor may 2002
*AA certificate of of history*
new altinator jan 2004 (with reciept)
new battery 21 feb 2005 (with reciept)
oil temp, pressure and boost gauges (with recipt)
many more reciepts
2 spare heads, spare turbo and two spare kn cones
car will have years mot too
2500 if interested
subaru mica blue
90 spec spoiler
de-locked
many more reciepts
2500 if interested
h-reg 100k 90 spec grey
looks great with six months tax and test
bargain
https://passionford.com/forum/viewtopic.php?t=171780
am local to you, live in north london and work in west london (park royal/ hanger lane)
bargain
ENGINE: 250 Bhp // 248 Lbs Torque @ 26 PSI
: Tunned and preped by SCS and Harvey Gibbs
: 7:6.1 compression ratio using Mahle pistons
: Mildly ported head using standard cam
: K+N panel filter
: Modified fuel system ( for increased fuel pressure when on WOT only )
: Hybrid T3 turbo 360 degree thrust bearing
: 48 exhaust housing
: 60 trim compressor
: 31 actuator
: Ahmed Bayjoo open chip with revised ignition curve and 3 degrees advance
: GRS EVO 3 intercooler
: Two Kenlowe 2000 blow fans
: Samco hoses
: Scorpion stainless exhaust system
: Felpro Group A Headgasket
: ARP Strengthened Head bolts
: Iridium Spark Plugs
: Ford Motorsport HT Leads
: 2 Stage boost controller // 13 Psi or 16 Psi
TRANSMISSION
: Geartorque £1000 Gearbox with 1 years warrenty
: Enlarged IB5 mainshaft and bearings
: Uprated baulk rings
: Top speed = 157 @ 6250 in fifth
: AP Paddle Clutch
: B&M Quickshift Leaver
SUSPENSION
: Lowered 40mm at the front 40mm at the back
: KONI top adjustable dampers
: Powerflex bushes
: OMP front strut brace
: Custom made rear strut brace
BRAKES
: Wilwood `billet` aluminium 4 pot calipers
: 285mm red dot discs
: Wilwood poly-D race pads
: Braided Brake Lines
: New Copper rear brake lines
WHEELS & TYRES
: 7 x 17" Team Dynamics Monza alloys in Anthracite
: BF goodrich profiler G tyres on rear
: Falken Tyres on front with good tread
EXTERIOR
: Recent full respray and body restoration
: Smoked Rear lights
: Smoked side indicators
: Black Nurburgring Stickers on Rear and side
: RS Badges under indicators
: Underneath just been re-undersealed
INTERIOR
: Mint RS 3 spoke steering wheel
: Sony CD Player
: Sony 13cm Door speakers
: Vibe 300w 6x9's
: Vibe CBR120 Sub Enclosure
: Stealth Shelf
: Kicker Competition Amp
: Boost Control switch
: Fan Overide switch
: Flamer Kit switch
: Fire Extinguisher
: 88 Spec interior, Mint no scuffs or tears atall
: Cat 2 Immobiliser
: 6 Months Tax
: 12 Months MOT
Recent Service included
: Oil change
: New Oil filter
: New Spark plugs
: New Sump
Spares Included
: 2 Spare wing mirrors
: Spare boost pipe
: Sump
: Kenwood 6x9's
: Felpro headgasket
: ARP Headbolts
: Dump Valve pipe
Any Questions Ring Damien : 07818066354
PICTURES ON THIS LINK
http://bbs.rsownersclub.co.uk/showthread.php?t=81904
£2500 - as it needs to be trailered, metering units gone
: K+N panel filter
: 31 actuator
: Samco hoses
TRANSMISSION
: AP Paddle Clutch
SUSPENSION
: Powerflex bushes
BRAKES
WHEELS & TYRES
EXTERIOR
INTERIOR
: Sony CD Player
: Vibe 300w 6x9's
: Stealth Shelf
: Flamer Kit switch
: Fire Extinguisher
: Cat 2 Immobiliser
: 6 Months Tax
: 12 Months MOT
: Oil change
: New Oil filter
: New Spark plugs
: New Sump
Spares Included
: Spare boost pipe
: Sump
: Kenwood 6x9's
: Felpro headgasket
: ARP Headbolts
: Dump Valve pipe
