adjusment on konis for 2wd saff
Old Jan 22, 2006 | 10:40 AM
lammylama's Avatar
lammylama
Default adjusment on konis for 2wd saff
went to adjust my konis last night on my saff , done the fronts ok on the top mount but where is the adjustment for the rears???.....only had a quick look last night in the dark and couldnt see it
Old Jan 22, 2006 | 10:42 AM
KSA-Cossie's Avatar
KSA-Cossie
You have to take them off the car to do them m8.
Old Jan 22, 2006 | 10:43 AM
lammylama's Avatar
lammylama
ok mate cheers...once off how do you do it
Old Jan 22, 2006 | 11:38 AM
rapidcossie's Avatar
rapidcossie
compress them in a vice and turn clockwise turn it 180 degress for the first setting. 360 for the middle setting and 720 for full hard.
Old Jan 22, 2006 | 11:49 AM
lammylama's Avatar
lammylama
what settings do you lot generally go for?
Old Jan 22, 2006 | 12:08 PM
rapidcossie
mine are full soft still but planning to take them off and use the middle setting probs
Old Jan 22, 2006 | 05:57 PM
snow*'s Avatar
snow*
If you're going to go the effort of either dropping the rear end off the car or removing the shocks, then set them to the max hard setting to save all the dicking around in the future when they soften up.
Old Jan 23, 2006 | 10:34 PM
rapidcossie
full hard might make it a bit tail happy in the wet tho??
Old Jan 24, 2006 | 12:24 PM
lammylama's Avatar
lammylama
its already tail happy in the wet
Old Jan 25, 2006 | 06:01 AM
grunter's Avatar
grunter
my rears are set to soft and its tail happy in the wet to lol.... setting it to hard when i take the back end out so that as well as poly bushes should give me some fun
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
ajamesc
Sep 27, 2015 02:25 PM
Russ Payne
Sep 25, 2015 08:29 PM
