fooking freezin
Old Jan 21, 2006 | 09:11 PM
fezzanut's Avatar
fezzanut
Default fooking freezin
can someone help my heaters are shit on the hot setting they only blow warm and not for long temp gauge runs cool 2.changed thermostat.any ideas?
Old Jan 21, 2006 | 09:31 PM
pollocks's Avatar
pollocks
whats the condition of the water pump ?? sounds like it could be starting to fail to me
Old Jan 22, 2006 | 09:18 AM
ballin's Avatar
ballin
no its the heater matrix mate.....very common.
needs a new one easy job thankfully
Old Jan 22, 2006 | 10:05 AM
BRAMMER's Avatar
BRAMMER
yeh, once you've removed the dash, i've still got scares from the last one i changed.
Old Jan 22, 2006 | 10:18 AM
robert 123's Avatar
robert 123
i just flushed my matrix out
Old Jan 22, 2006 | 03:28 PM
fezzanut's Avatar
fezzanut
cheers guys i thought it was cos i changed the pump about a year ago so should still be ok.any idea how much they are cos times are hard as always
Old Jan 22, 2006 | 05:05 PM
Liams's Avatar
Liams
I paid Ł50 for a new one couple of weeks ago!
Old Jan 22, 2006 | 06:14 PM
fezzanut's Avatar
fezzanut
was that from ford mate or an aftermarket one?
Old Jan 22, 2006 | 09:42 PM
Liams's Avatar
Liams
I was told ford dont make them no more so it was a pattern part one! Only gota take center consol out so pretty easy really
Old Jan 22, 2006 | 10:52 PM
SafeChav's Avatar
SafeChav
Chances are its your matrix, check and see if the pipes going to it are nice and hot (both in and out), if they are, it could be gone, or it could even be something as simple as the flap in the box isnt closing properly, but more than likely the matrix, i would expect the out pipe to be colder.
I got a new one for my MK3 cabby and that cost me Ł20 new i think, or maybe Ł28, i forget now but it was aftermarket, heaters are almost too hot now lol
Old Jan 22, 2006 | 11:06 PM
rst in breaking's Avatar
rst in breaking
howdoes the dash come out as i have to do this and some othewr work? ive taken 2 screws from either side of the dash one behind the ash tray the ones along the top of the dash any more other than disconnecting clocks?
Old Jan 23, 2006 | 06:04 PM
fezzanut's Avatar
fezzanut
both pipes are hot in and out.if i let my car warm up without heaters on then switch them on they will be hot for a bit and then go cold so i switch them off to let them warm up again etc as its brass monkeys at the moment.and my temp gauge stays so low i never have to switch the cooling fan on(manual)unless im stuck in traffic.do i have to take the dash or can i get the matrix out with the centre console out of the way?its a frst and cheers for any help guys
Old Jan 23, 2006 | 06:13 PM
SafeChav's Avatar
SafeChav
Hang on, hang on, what does the temperature gauge read when you have the heaters on, does it go right back down to cold? and do the heaters go cold when you start driving?
Old Jan 23, 2006 | 06:36 PM
Liams's Avatar
Liams
Yep you only have to take out center consol done mine couple of weeks ago, I took the front seats outa mine for more room but thats far easier than havin dash out!
Old Jan 23, 2006 | 06:46 PM
SafeChav's Avatar
SafeChav
i'll bet its your thermostat
Old Jan 23, 2006 | 07:55 PM
fezzanut's Avatar
fezzanut
the temp gauge reads about a quarter when driving with heaters on or not.they dont go cold id say luke warm but it defo aint hot and they get colder when at a standstill.changed the stat couple of weeks ago still the same.also heaters aint very powerfull.
Old Jan 23, 2006 | 10:33 PM
SafeChav's Avatar
SafeChav
Hmmm if you've changed the stat then i'd guess its not that, to be honest the heaters should get hotter when you start driving even in this cold weather, because the coolant is flowing around faster, mine almost burns when you drive lol.
Check the flap is closing properly in the heater box (sorry i dont know how easy this is i dont own a fiesta ), and presumably if you say you did the pump about a year ago, and a stat recently the coolant should be nice and clean (not all sludgy)
Old Jan 23, 2006 | 10:45 PM
Liams's Avatar
Liams
I found that my cars engine temps was running hot all the time coz I suppose the matrix being blocked stops your water flowing round properly! When I had the matrix out I did flush it with a hose but not alot of crap came out but I still changed it anyway as I had bought the new one and hey presto had heaters again and car ran cooler! Only other thing I suppose is your water pump getting bit lazy?
Old Jan 23, 2006 | 10:51 PM
SafeChav's Avatar
SafeChav
I doubt the pipes are blocked as he said both the pipes are nice and hot, and i believe he said the car had a new pump about a year ago??
Old Jan 24, 2006 | 05:52 PM
fezzanut's Avatar
fezzanut
ive had a think about it and if my pump was failing my car would overheat.if my matrix was blocked slightly it would explain why the heaters get cooler when you leave them on cos whatever shit amount of coolant that its carrying due to poor flow would be cooled by the fan inside the car,also explaining why they go warm if you turn the heaters off for a while then back on which is allowing time for more hot coolant to enter the matrix.what do u reckon does it make sense
Old Jan 24, 2006 | 06:24 PM
SafeChav's Avatar
SafeChav
Possibly, i'd check the flap was opening and closing properly, otherwise you might end up struggling over the matrix and find its no better. The coolant flow through it should be continuous, if it was blocked usually the out pipe would be cooler/cold (depending of course on how blocked it is).
Whats the cooling system like condition wise, any signs of over heating/negligence (like orange stained bottles, orange stains on the engine bay around the bottle, and brown sludge in the bottle)
Old Jan 24, 2006 | 09:39 PM
Liams's Avatar
Liams
If I put me heaters on luke warm air would come out for bout 10 secs then go cold so I think ya best bet is to change the matrix, there not that expensive so I would use it as a starting point, if that doesnt work then you know the problem lies somewhere else!
Old Jan 25, 2006 | 07:00 PM
fezzanut's Avatar
fezzanut
cheers for your help guys im gonna see if the flaps shutting fully if it is then im gonna flush matrix out on weekend.im gonna try and do it in place cos i aint got time and hopefully it will cure it.cheers again ill keep you posted and hopefully get some photos up soon piper285t2,hybrid turbo technics t2,pace intercooler,chip,samcos,full stainless longlife,ap 4 paddle clutch,cts stage 1 lsd,15 psi 175bhp,180lbft.
Old Jan 25, 2006 | 07:04 PM
SafeChav's Avatar
SafeChav
Let us know how u get on
Silly you've done it now you've mentioned pictures you know how mad for them we all are
Ben26
Aug 27, 2015 08:56 PM
cameron2
Aug 10, 2015 12:14 PM
apples24
Jun 29, 2004 08:25 AM
