Front TCA for 3dr cossie!
Is there any possibility to get hold of original non-adjustable TCA`s for 3dr cos in england? they are no longer available trough ford dealerships in norway.. can still get the ones from sapphire, but they won`t a 3dr..
help, anyone?
help, anyone?
Here's a little secret. The 3dr ones are IDENTICAL to any Mk3 V6 Granada (Scorpio) TCAs. That's where Ford sourced them from. So any Granada/Scorpio V6 from say, 1986-1991 will use them. So go to the junkyard and get some. But it must be from a V6 model.
I tried the V6 granada arms but fount they had a wider track m8. All the other arms have different swivel pin size's ie smaller and the inner bush steel inserts are all 10mm where the cossie's use 12mm.
Good luck with your hunting chap....I gave up and found a second hand unit insted.
