Wheres your ACT guage mounted?!?!
Yeah i've got the pod on the steering wheel column but thought it would be more arse ache trying to bodge a block of something to mount it on the opposite side.
Oranoco, i've already had the clock out & apart just not to sure i want to mount it there?? PS the top part on the dash near the drivers side A pillar......Paul Ripley did that!
In my FRST its in the instrument cluster, my car doesn have ABS so i move the brake warning light and the handbrake light over to the right and opened the slot up for the gauge. Mines a ACT gauge from Nomad Racing which i found to be considerably small than some of the other avalible, not sure which one you have.
I'll try and get you a picture if your interested?
Thanks
Matt
Thanks
Matt
Matt,
Can you post a pic i'm interested!!! I thought of that but didn't realise you could move the little lights about!
Bugger more chopping of the dash, thought it was had enough cutting in a Elliot rev counter.
I'll get you a pic when i get home. To move the lights to need to cut some of the plastic hosuing behind the lights about becuase theres only one bulb for both lights, so you need to cut a hole for the light to get through.
Thanks
Matt
Thanks
Matt
you know it makes sense to go next to your boost gauge pod mate!
Ian's done the factory look onwe in the clock too for someone bu tit lokks better right in front of you!
Oh and the lower arm price sounds a gooden matey!
Now get the bloody car running will ya? oh and i want my pipes back from ripley's car
Gaz,
what the fugg are you going on about?? Pipes off Ripleys car??
And your ment to reply to texts on mobiles, you tight fugger!!
And Ian's prices are abit tooo steep for me ta! Esp when i can get you to make it at half the price!
I had the same promblem i didn't know where to put my ACT in my series 1. But what i did i took all the guts out of my roof mounted clock made a slight mod and fitted where the clock would be. Looks like it came out of factory with it there.
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
