Fitting a Bailey mirror image tank
Old Jan 18, 2006 | 05:00 PM
turbocat's Avatar
turbocat
Default Fitting a Bailey mirror image tank
Hi can anyone help me Where do all the pipes go for fitting the image tank. Ive not got an oil separator. Do I have to put a hole in the rocker cover. Thanks
Old Jan 18, 2006 | 05:13 PM
dave cos4x4's Avatar
dave cos4x4
you will have to put a hole in the top.
not too sure wgere all the pipes go to but if you do a search you will find the info you need.
Old Jan 18, 2006 | 06:38 PM
Speedy G.'s Avatar
Speedy G.
You do NOT have to put a hole in the top of your camcover.
Old Jan 18, 2006 | 06:45 PM
turbocat's Avatar
turbocat
F**k just took the rocker of. It is a better though to put the hole in the rocker cover is it.
Old Jan 18, 2006 | 06:47 PM
Speedy G.'s Avatar
Speedy G.
I thought it was better not to do that m8.
Give me a few minutes and I'll try to dig something up about the fitment of my Bailey mirror image tank.
Old Jan 18, 2006 | 06:52 PM
Speedy G.'s Avatar
Speedy G.
Look there --> the first post I could find.
There should be another.
https://passionford.com/forum/viewtopic.php?t=103270
Old Jan 18, 2006 | 07:03 PM
Speedy G.'s Avatar
Speedy G.
The part supplied by Bailey which they claim is the oil return. Well, it isn't.
The bung needed to remove under the turbo
The part I got to replace the standard breather
The part made up for the turbo side to breath
Don't know about the Bailey kit. They do NOT supply the right fittings to install it correctly. Had to make up my own and the car is STILL at the garage at the moment as they do not seem to find any time to work on it.
Old Jan 18, 2006 | 07:43 PM
dave cos4x4
well looking at the post by Dave,you need the hole in the top for a 4 port system.
i must of always had the 4 port system.
Not sure if the mirror image tank is a 4 port but my mate has one and his has a hole in the rocker cover.
this may help.
http://www.grahamgoode.com/cosworth/frfaqs.htm
Old Jan 18, 2006 | 10:06 PM
big-dirty-dog's Avatar
big-dirty-dog
heres mine hole in rocker cover-pipe to tank then pipe from tank down the back into the sump i think(never looked )also a pipe at the bottom on the right of the tank as you look at pics which vents to atmosphere
Old Jan 18, 2006 | 10:19 PM
turbocat's Avatar
turbocat
Thanks Guys. Its been sent out should get it friday. I will let you no how I get on.
Old Jan 20, 2006 | 09:37 PM
rstoughy's Avatar
rstoughy
Heres a pic of mine,
Although mine is a GGR one.
No hoses in to the rocker cover though.
I can get better pics tomorrow if you want
Old Jan 21, 2006 | 06:47 PM
turbocat's Avatar
turbocat
Thanks guys. Ive fitted it today and looks spot on. Just waiting for the rocker cover to come back from the polishers.
Old Jan 21, 2006 | 07:16 PM
macker's Avatar
macker
HERES MINE
Old Jan 21, 2006 | 08:52 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
turbocat - Thanks for the order Hope you've managed to fit it ok now.
Old Jan 22, 2006 | 12:16 PM
turbocat's Avatar
turbocat
Thanks Dan for your help.
steerfromdarear
28
Jan 29, 2016 06:14 PM
matman
Sep 9, 2015 05:45 PM
john_3.0s
Aug 15, 2015 07:44 AM
155lee
Aug 14, 2015 11:21 AM
COSWORLD
Aug 14, 2015 07:40 AM
