L8 to P8
Old Jan 18, 2006 | 10:18 AM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Default L8 to P8
Whats needed to convert saph cossy 4x4 L8 ecu to P8 for dizzyless and ALS, and where to find parts, rough price guide etc.
Many thanks for any advice.
Brian
Old Jan 19, 2006 | 02:55 PM
*Bri.4.b.Cos*
any one??????
Old Jan 19, 2006 | 07:33 PM
nik t's Avatar
nik t
the p8 will go on the standard loom.But 2 run the als and dizzyless as well i think you will need 2 get a new loom. Give joe at bluesprint a ring or fields motorsport.
Old Jan 20, 2006 | 09:03 AM
foreigneRS's Avatar
foreigneRS
Testing the future
most will say that to run anti-lag you will require a pectel board.
to run dizzyless, you just need it enabled in the eprom
Old Jan 23, 2006 | 01:20 PM
*Bri.4.b.Cos*
Cheers lads
Bri.
Old Jan 23, 2006 | 11:12 PM
jon@work's Avatar
jon@work
You're right - most people do say that. I'm running ALS without a board.
PS You don't need a new loom - just a minor mod to your current one.
Old Jan 24, 2006 | 07:47 AM
foreigneRS's Avatar
foreigneRS
Testing the future
jon@work
Old Jan 26, 2006 | 09:37 PM
polly_x's Avatar
polly_x
How do you run ALS in a P8 without a board? Or are you using some separate controller?
Old Sep 21, 2006 | 11:18 AM
Stu @ M Developments's Avatar
PassionFords Creator
Missed this one...
The ALS is NOTHING TO DO WITH HARDWARE.
Its totally software controlled and all in teh EPROM.
The Pectel ALS boards are just running a different encryption algorythm to a normal Pectel P8 board so they can quite rightly charge more for it.
Old Sep 22, 2006 | 10:52 PM
cosy trav's Avatar
cosy trav
you dont want to run to much als or your turbo wont last long unless you have a maram shaft or gt turbo .
your the daddy at this stuff stu .
