300 bHP from a small turbo escort?
Old Jan 18, 2006 | 07:47 AM
cosworthbg's Avatar
cosworthbg
Default 300 bHP from a small turbo escort?
Is this possible and what upgrades are needed?
Old Jan 18, 2006 | 12:29 PM
cossymad's Avatar
cossymad
Boost
Chip
Turbo
Air-filter
Exhaust (de-cat)
287 bhp
Boost
Chip
Cams
Turbo
Air-filter
Exhaust (de-cat)
303 bhp
Defo worth getting fuel pump too, although I have n't on mine
Old Jan 18, 2006 | 04:11 PM
M.A.D.RST's Avatar
M.A.D.RST
How does this compare to a tuned big turbo escos? What sort of power would be similar?
Old Jan 18, 2006 | 04:15 PM
maxest's Avatar
maxest
Well Chris's small turbo trousered a 330 big turbo, in a Performance ford grudge match....
Old Jan 18, 2006 | 04:23 PM
cosworthbg's Avatar
cosworthbg
Who makes chips for small turbo escos??
Old Jan 18, 2006 | 04:47 PM
boostaholic's Avatar
boostaholic
GGR do a 305 conversion it must be top notch knowing them!
Old Jan 18, 2006 | 05:21 PM
ryan_belfast's Avatar
ryan_belfast
Ive got
Chip
T28 Hyrid
Actuator
Boost (as you say lol)
decat
full system
fuel pressure regulator
fuel pump
I didnt know you could get cams for a small turbo escort cosworth.
Old Jan 18, 2006 | 07:26 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
Originally Posted by Ryan_Belfast
Ive got
Chip
T28 Hyrid
Actuator
decat
full system
fuel pump
i have the above and i have 298bhp 320lbft, but i now have uprated coolers so shud see just over 300bhp
so it is possible i am converting over to autronic this year so will sell a few bits, altho i have a spare uprated fuel regulator if your interested??
Old Jan 19, 2006 | 04:51 AM
danielT28's Avatar
danielT28
Ive got
Chip
T28 Hyrid
Actuator
decat
full system
fuel pump
Hoi what is You boost pressure , I have eGGR 305 conversion is run 1,2bar boost on standard turbo. (My englisch is not so good)
Greetings from BELBIE
Old Jan 19, 2006 | 08:12 AM
cossymad's Avatar
cossymad
I do a chip for the Escort Cosworth EEC4.
290bhp small turbo beats a 330bhp large turbo upto 100/110, after this it's pretty even, but a good 330bhp one should see higher top end, although I seen GPS verified 161mph (258kmh).
I can get cams for small turbo one, although this has given me 16 more bhp and midrange power, low down pulling away has suffered.
Mine runs @ 1.5bar exactly (21psi).
Old Jan 19, 2006 | 10:20 AM
sailorbob's Avatar
sailorbob
Originally Posted by cossymad
I do a chip for the Escort Cosworth EEC4........ I seen GPS verified 161mph (258kmh).
Did you have to alter the speed limiter setting in the chip for this?
Old Jan 19, 2006 | 12:30 PM
cossymad's Avatar
cossymad
Altered.....removed along with the boost limiter and rev limiter
Old Jan 19, 2006 | 01:44 PM
ryan_belfast
If my small turbo runs 1.4 bar of boost, it backfires a little on full boost, at 1.3 its fine, how the hell are you running 1.5?
Old Jan 19, 2006 | 02:12 PM
cossymad's Avatar
cossymad
"If my small turbo runs 1.4 bar of boost, it backfires a little on full boost, at 1.3 its fine, how the hell are you running 1.5?"
Colder heat range Denso's plugs, No boost limiter, No rev limiter etc
I guess as it is KPa it's more like 1.428bar (20psi)!!
Old Jan 19, 2006 | 02:23 PM
ryan_belfast
Sorry if you thought that was rude i didnt mean it that way i just wanted to know what mods you had to run that boost cos i wanna run it lol
Old Jan 19, 2006 | 02:26 PM
cossymad's Avatar
cossymad
I didn't for one minute think you were
No offence taken
Old Jan 19, 2006 | 02:53 PM
ryan_belfast
No offence taken
excellent
now to copy u :P
Old Jan 19, 2006 | 09:47 PM
adamski frst
i run 1.2 bar
Old Jan 20, 2006 | 12:52 AM
S1rst's Avatar
S1rst
Chip
Actuator
Boost
TT Turbo
FPR
Uprated FP
Cams
Magnex De-cat
Aquamist
Have a graph for 322 bhp (before aquamist). Some may say its out a bit as it was done at well lane, which some say is known to over read but cant be that far out, surely. Still, gotta be over 300 bhp.
Old Jan 20, 2006 | 05:55 AM
macker's Avatar
macker
Looking to chip mine as it has never been chipped. Cossymad, how much would it cost me? currently have a full mongoose stainless and K&N Induction kit plus all chrome goodies
Old Jan 20, 2006 | 07:34 AM
cossymad's Avatar
cossymad
A chip to 'a' spec is Ł300.
With the other mods you have it'll work v.well
Old Jan 20, 2006 | 08:00 AM
macker's Avatar
macker
do i need to change the actuator, turbo ect? wot sort of bhp would i gain of your chip with mods i already have. take it `a` spec is A Bayjoo???
Old Jan 20, 2006 | 11:41 AM
cossymad's Avatar
cossymad
NO, BUT THE STD TURBO'S ALREADY SHORT LIFE WILL BE EVEN SHORTER!! YOU'LL NEED TO ALTER THE BOOST BY THE ACTUATOR PRE-LOAD AND THEN FINE TUNE IT WITH A BLEED VALVE. WHEN YOU CHANGE THE TURBO, I HAVE THE PERFECT COMBINATION AND WITH A ACTUATOR ON THAT, BHP GAINS WILL BE ANOTHER 20BHP ON TOP AT LEAST.
wot sort of bhp would i gain of your chip with mods i already have?
AT LEAST 30BHP ON IT'S OWN
NO. 'A' SPEC IS A SPEC THAT WE DECIDE, IN OTHER WORDS WHATEVER SPEC WE NEED FOR YOU!!!
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
