Co% on 2wd saff
Old Jan 16, 2006 | 12:55 PM
opposite lock's Avatar
opposite lock
Default Co% on 2wd saff
Hi , just had M.O.T done and passed with a CO value of a fraction under 2% Is this ideal , she,s got an stainless ex and K&n L6 with standard chip .
Im thinking its a bit too low and would be ideal with more of a richer burn .
any help will be appreciated
Old Jan 16, 2006 | 07:50 PM
snow*'s Avatar
snow*
Hi mate, someone will correct me if I'm wrong I hope but this is what I was told a while ago by Woodford Garage Motorsport.
> * At Base Idle 800-850RPM - 3.5% Max
> *At 3500RPM no less than 1.5% ( ideally 1.5% - 2%)
Old Jan 17, 2006 | 07:31 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the AFR at idle bears little or no relationship to the AFR throughout the rev and load range, although if you have a standard chip it should all be alright (depends what improvement the inlet and outlet breathing mods that you have done have had).
i wouldn't worry about it if you are running std boost.
Old Jan 18, 2006 | 05:38 PM
opposite lock
cheers guys
mark r
Sep 29, 2015 07:27 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
ajamesc
Sep 27, 2015 02:25 PM
Russ Payne
Sep 25, 2015 08:29 PM
