WINDOW RUBBER??
The window rubber that runs along the edge of the door horizonally at the bottom of the window on the outside, is it held in by being pushed in place?, has anybody replaced it/how much? mines looking a bit worsed for wear
...cheers
S1 and S2 are different ones but exchangeable. The S2 ones are around 10mm taller. If you have a S1 inner rubber and S2 outer rubber, you will see the miss match in height from inside. I had so much trouble finding the S1 rubbers so had to settle with the newer ones.
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
