Series 1 Windscreen Wiper Speed Control Knob
Old Jan 12, 2006 | 09:26 PM
Series 1 Turbo's Avatar
Series 1 Turbo
Default Series 1 Windscreen Wiper Speed Control Knob
Does everybodys knob waggle around or is it just mine?
I think I might need a bush to sort it out
I also have the problem with it coming out all the time under full speed
Can you get a new bush from ford?
I think I need one.......
but there is a serious question in there somewhere lol
Old Jan 12, 2006 | 09:28 PM
Series 1 Turbo
Even somebodys old bush will do that someone has finished with?
Old Jan 13, 2006 | 05:26 PM
rswoza's Avatar
rswoza
pull the knob off theres a "o" shaped ring that goes down the center shaft, using an electrical screw driver just put it in the hole locate it in one of teh slots on teh "o" ring and turn it clock wise to tighten the thing up.... or from behind the dash ( take out the pocket to the lower right of the dash under the steering wheel) theres a plastic nut on the back of the control switch just do it up finger tight.
Old Jan 13, 2006 | 06:17 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
aaah i thot mine was cunted, as it just falls out also and doesnt seem to do anything! does this work the front or rear wiper speed? i thot my front wipers were slow
Old Jan 13, 2006 | 09:58 PM
SI-S1's Avatar
SI-S1
my one has never worked.
Old Jan 14, 2006 | 11:53 AM
JimmyBoy's Avatar
JimmyBoy
hmmm, so you got a waggley knob abd you think a bush will sort it out? , I think I am suffering with the same problem as you!, I shall go out tonight and try to find me a bush!
Old Jan 15, 2006 | 09:14 AM
flax's Avatar
flax
i ripped mine out and stuck my boost adjuster in there. if you bypass it you still get intermittent wipers just cant adjust the frequency obviously.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
